347 Dart block sbf
* Motor fresh 347 *
* Dart block Part # 31354175
* Custom Diamond Blower pistons
* Custom Comp Cam
* Trick Flow 170 CC Track Heat ported heads
* Trick Flow 1.6 rockers
* Bee-Hive valve springs
* 10 degree locks
* Comp push rods
* 4340 Eagle Crank (still standard)
* Eagle H-beam rods up graded rod bolts
* Precision oil pump
* All ARP studs, heads, mains
* Professional Products damper
* Stefs aluminum oil pan
* Clevite H series bearings
* FelPro MLS head gaskets 1134
* Total Seal Bower rings
5500.00
Daum that's a deal...... I just put a 347 in my car and will do a dart block next year or i'd be all over it....... good luck with the sale what did it put down?
How much for the short block?
I will have to get back with you have a deal pending will know later today.
