I decided to just list the car on Racing Junk for sale here is the ad. The car is going to eventually be listed on ebay.
1974 Big Block 505 Camaro for Sale. Car was featured on Pinks Season 5 Episode 1. We(Stangbangerz) won this car on the show and had to replace the transmission since it was slipping in high gear. car is strictly a race car with fiberglass front end including hood. Car will need some TLC. Car runs and drives and has no problems that I'm aware of. Interior is bare with just some carpet and a racing bucket seat. Car does has a roll cage but I dont know if it meets certification requirements or not. Body is in good shape and has lexan glass all around.
Engine Specs
505 ci big block chevy,
Probe 12.5 pistons, forged
Eagle H beam rods
Scat 4.250 stroke crank
Balanced assembly
GM casting # 990 heads
2.25 and 1.88 Ferrea ss reduced stem valves
Comp Cam Star series valve springs for solid roller
Titanium retainers
Comp Cam solid roller lifters
Comp cam custom nitrous grind: I 281*@.050 lift
with .799 lift
E 292 @ .050 lift with .782 lift 112 lsa
Heads and intake are ported, intake is port matched to heads
1150 dominator holley carb
Transmission
Built Turbo 400 transbrake. Nitrous Converter. Transmission and converter are fresh no passes.
Rear
Ford 9 inch disk brake rear end
Aftermarket rear control arms
Cal-Trak Supsension
Autometer Guages and Tach
Edelbrock progressive nitrous kit with controller adjustable up to 400.
Wheels
Jegs aluminum wheels on all 4 with 28x10.5x15 ET drags on the back.
Car on the chassis dyno made 440rhwp through a really loose nitrous converter that has since been freshened up. Should make 500+NA on the dyno.
I have more pics if anyone is interested.
Listed for 11,500 OBO. Money goes to Holly and Amanda(Vinny's daughter)
