I recently purchased a D1SC and plan on running it in my coyote swapped fox. I am wanting to start gathering up some parts so I have everything I need come fall to get it installed on the car.
Plan is to get it on the car and run 10-12psi. I currently have a 4.13 pulley but will buy whatever I need to get me in that range. I am currently running two tunes and switch from 93 and E85 as desired. I would like to still be able to do this so the injectors would need to be sized accordingly.
I wanted to see what size / brand injectors you guys recommend?
Also, I currently am running a TI450 fuel pump (I believe) purchased from Walter. How much power do you think this pump can support on 93 and E? Will I be safe at the 10-12# level? I’d like to keep this pump in the car is I can and not change it.
