As you all know, I picked up a 92 Coupe off of a buddy of mine that is also on here slow86fiveoh (Marcus). It was on here for sale a couple times I think. Charlie Taylor had it, then Jason Crabtree. Its a pretty clean little car.
As for the car. It has a stock 5.0 that has been freshened up. Stock down to the clutch fan and throttle body. It has an On3 kit with a 70mm turbo set at around 6 pounds right now, 39lb injectors, PiMP XS system and a 255 pump. Transmission is a PA C4 with a PTC converter. Converter is a little on the tight side so it may get pulled and sent back for a re stall. 8.8 has a 3.27 gear. UPR uppers and lowers, and Mac exhaust.
Already swapped the front suspension. Added the Team Z K member and A arms, Strange struts with 14-150 springs and manual steering rack.
Took it to Edgewater a few weeks back. Made 2 passes, both not making any boost till just at the 60' marker. Went a 12.67 @ 107. Plenty of room for improvement.
I have a ported truck lower I got from Greg (Kwik92GT) to go along with the Systemax upper and a 70mm throttle body. A set of Holley heads also came with it.
I have the 5 lug front spindles and rotors that I salvaged off of the 94 that I picked up from Chad393na that I may use to swap it over to 5 lug so I can run the 17" Alumastars on the front.
Plans are to crank up the boost and see how it does. Id like to throw a set of Trick Flow 11r heads on it as those will allow me to grow into them later on. Not sure how they work with the stock bottom end though.
https://live.staticflickr.com/7892/3...c9588ca0_b.jpgIMG_20190209_171557459_HDR by Brian Mcwhorter, on Flickr
https://live.staticflickr.com/7890/4...0d8c6265_b.jpgIMG_20190209_175038170 by Brian Mcwhorter, on Flickr
https://live.staticflickr.com/7803/4...a7d88f70_b.jpgIMG_20190209_165408456 by Brian Mcwhorter, on Flickr
https://live.staticflickr.com/7880/3...aa22893c_b.jpgIMG_20190210_171213447 by Brian Mcwhorter, on Flickr
