Congrats
Congrats
Short video of the start up and idle, what do you think? Let's be nice now, it's been 3 1/2 years for this moment.
http://vid1096.photobucket.com/album...psou7x0ri3.mp4
http://i1096.photobucket.com/albums/...psou7x0ri3.mp4
Damn sounds good hell yeah man nice work!
Sounds pretty nasty!!! Glad to hear it run after all this time! Bet you was smiling ear to ear!!
I'm still smiling Brian, Thanks
Sounds just like mine. Lol
Not quite, but close. Lol
Sounds awesome, congratulations!
Thanks Rick, makes it so much more worth it now that it is running. Still some things to do and change but it should be ready for the track.
holy crap Shayne!!! WOO-HOO!! Sounds awesome. Just got goose bumps.
Awesome job! All your hard paid off. Congrats Shayne.
Very Nice!
Congrats! Sounds great.
That's a clean engine bay! Sounds rowdy! Nice work!
I think my b-hole just puckered up a bit.
Thanks everyone, it is exciting...
Now on to some other stuff to finalize getting this ready for spring.
It surely draws attention with open headers and somewhere in the neighborhood of .720 lift on a solid lift roller cam, it's a little rowdy as some of you have stated. Lol
Also, it shakes things of the walls and shelves when it is running, wife has been patient with it so far. Lol
I have been telling her that it was going to run by this spring and she was questioning that, not any more. Lol
Had to make some changes on the fuel lines from 8an to 6an to allow the throttle bracket to fit, I still had to grind down some of the bracket to get the fuel line to clear. Getting things done slowly but surely.
http://i1096.photobucket.com/albums/...psbptw1snf.jpg
http://i1096.photobucket.com/albums/...psip55krei.jpg
Out of curiosity why is the front bowl fuel line on the drivers side? It's not something you see often.
With mounting the regulator in the front of the engine, I felt the most sense was to go to the rear fuel bowl on the passenger side and to the front fuel bowl on the drivers side.
Worked on wiring in the lights for the Auto Meter dash gauges last night, not finished but made some progress.
Good job buddy! Im ready for this snow to clear up and start getting out again! Cabin fever is killing me!
Thanks Brian, I'm really looking forward to warmer weather myself. Once I finish the dash lights or at least in the process, I need to wire in my line lock and transbrake too.
Here is a sneak peak at the gauges with the lights functioning.
http://i1096.photobucket.com/albums/...pss7tmkfbz.jpg
Warm weather is coming!!! I expect to see a video soon of it out cruising!!!
I'm ready for the warmer weather, I may be able to get around the block and back before the neighbors possibly complain. Lol
For now it will primarily be a strip car until I can get all the factory wiring reinstalled.
Finalizing the trans brake wiring and then I will run it through the gears on jack stands. Once that is completed, I may take it out on the street just to see how she acts today.
Hell yeah!! Good to hear!
Ran it through the gears successfully today, good deal, that much closer to getting it worthy now.
So I was tired of making a mess on the garage floor with the coolant, so I did this. Mounted it inside the driver's front fender, keeps it clean under the hood and it is functional. I can still keep an eye on it while I'm under the hood. What do you think?
http://i1096.photobucket.com/albums/...ps85vd4iwl.jpg
http://i1096.photobucket.com/albums/...psp1uujjhy.jpg
http://i1096.photobucket.com/albums/...pscvvqej4z.jpg
The only thing I see that may be bad is if the hose pops off or it breaks and spills under the tires. That wouldn't be good!!!
I thought about that as well but not sure there is any true spot to mount it that some coolant may not affect that. The best bet would be the center of the engine compartment then, I guess it could be mounted in front of the radiator, just wouldn't be as clean looking under the hood.
I had an aluminum overflow and Gary welded it right to the radiator. Very clean looking and about 8 inches of hose running to it. I don't know if I got any pictures of it but Ill check.
Here is a crappy picture. You can see it though.
http://i661.photobucket.com/albums/u...ps33f5f0bf.jpg
That's an idea, I can look into that here soon. Just wanted something at this time to prevent any further messes from the coolant.
Yeah I know what you mean! In time!
Just a small update but no photos to show at this time. Getting ready for the Stang to make one more trip to the chassis shop (Rogue Racecars), hopefully this will be the final trip for quite some time.
First, the 9" housing end that is welded onto the 8.8 has a pinhole leak, needs to be fixed.
Second, the 8.8 is going to get the Team Z reinforcement kit installed to keep the axle tubes from twisting under heavy acceleration.
Third, the rear end is going to get a wishbone installed to keep the 8.8 straight under heavy acceleration.
Fourth, mounting of the GM 1-wire alternator to keep power coming to the system, brackets and spacers will need made for this.
Fifth, need to look at modifications to my existing trans cross member, my 3 1/2" exhaust will not fit with the current one.
You already have the Team Z brace? Josh Ashley is local and makes a bad ass brace! I can get you in touch with him if needed.
Jegs and Summit sell a one wire alternator that is in a Ford housing. Should make mounting it a lot easier. I used the gm style on my big block Mopar and had to make brackets but would have saved time to use stock style mounting brackets.
