Loved seeing the video of your first cruise! Bet that felt good!
I decided to dump the wastegate into the exhaust. It’s so hard to weld a thin heat cycled piece of 409 to 304 with a stick welder. It’s easy to weld 16ga or larger metal though. I think it turned out pretty good after fighting with it.
https://i.ibb.co/LYJLMjp/A5-FC99-F1-...-C2-D49-DD.jpg
https://i.ibb.co/vmkwN8K/6923-D0-C1-...B020834889.jpg
https://i.ibb.co/MyzNNXp/FB9-C6160-C...EDE1633786.jpg
Awesome job man!!
Any plans to try to hit the track before the white stuff flies?
Nice job Joe. Good to see it moving over asphalt.
Flames are Cool !!!
Me too, I made more tuning progress today than I did in the last two weeks. I was wondering why I wasn’t making any boost and I just found a loose clamp to the intercooler behind the passenger headlight. I’ll have to wait till later this week to try. I just need to get the car to come down to idle slower. It overshoots and dies sometimes at stop signs.
they really are and they are very attention getting,lol!
I hope you get that 11!
Funny story yesterday I was going around within a mile of my house trying to get my drivability right. A guy in a Prius started yelling at me while at a stop light. Unfortunately I couldn’t hear him over my exhaust,haha.
Finally got to give the car some gas and it wasn’t showing any boost. I found some boost leaks yesterday. It was leaking heavily around the back of the intake and around the a lot of the vacuum port points. That’s all fixed now except for the brake booster port which I should have fixed tomorrow.
https://i.ibb.co/YRmdTps/E0-CB3460-0...07548-F3-D.jpg
https://i.ibb.co/2MTwY9c/A2125416-42...4-F2022-EE.jpg
https://i.ibb.co/qxMbnBf/E5187131-36...2-EA61-E56.jpg
https://i.ibb.co/b2Sg51j/1-E8-EEAE7-...24-DCF99-F.jpg
https://i.ibb.co/hfzX9sg/028-B4383-F...-C666-D8-D.jpg
I accidentally found the above 1:24 model online so I bought it.
I like the model!!
Hope you have the boost leaks fixed now. If not just crank it up more!!
Found a leaking V-band before the turbo. As soon as put the car back together I’ll see if it makes boost.
Still having boost issues. Found that I’m having leaking issues. Using water, soap and a shop vac to find my leaks. Sealed up one of three pipes before the turbo today. Also purchased a more forgiving exhaust manifold gasket and vband seals.
https://i.ibb.co/TqJKfJS/C584-A2-A9-...5-F8566137.jpg
https://i.ibb.co/wR8yygg/FEEECE89-87...CC3-D5-D90.jpg
https://i.ibb.co/2YVRkMF/342-ADC16-2...-CB9-BF165.jpg
https://i.ibb.co/48QdHHX/FF532-C6-A-...39093561-B.jpg
Got some slit wire loom for Christmas. Cleaned up the engine bay this morning.
I been hunting for my boost leak and I can hear it under the intake manifold. I found I can buy a new GM one for 120 dollars with all the gaskets and seals so I did that. I installed the map sensor and air sensor this morning by increasing the hole opening size to accommodate them. I also decided to get a bigger intercooler while I’m at it. After I get the boost issue resolved I’ll install it in place of the current one.
https://i.ibb.co/5XZxK51/90548553-F4...5-DBB0-A41.jpg
https://i.ibb.co/zNJPsWq/BFC0-A941-E...051-D5-DC6.jpg
Hope that fixes it for ya. Going to be cool to see it make some passes with some boost!
Didn’t fix it. Not 100% sure where I’m loosing the pressure. I have some exhaust plates on their way to block off the heads output. I don’t remembered having these issues boost testing 4 cylinder cars. Not sure if I need to clock the motor a certain way.
That sucks. You'd think it would be just the same. 0 pressure?
Getting about 3 psi.
Did you make sure the fire cone was installed on the wastegate seat when you installed it to the flange?
I got the heads blocked off at the exhaust side. It’s building pressure. I have some air escaping the wastegate and some escaping my welds. I’m going to have to weld the exhaust more and figure out how to have it seat better or get different style wastegate.
Does it have any heavier springs you could put it in?
My 3400 stall arrived. I should be picking up an explorer 8.8 4.10 next Friday.
https://i.ibb.co/QcNNRJ9/2-F7-C50-DB...455-CB9-CB.jpg
Nice!
Is your car leaf spring or coils?
Gotcha. What all does it take to put the 8.8 in it? Same width?
I will have to buy a mount kit and shorten one sides axle. It will be 57” wide instead of the Volvo’s 55” width. I’ll probably get it drilled to 108x5 to match the Volvos pattern.
https://i.ibb.co/1KtpT04/2-D696413-2...-FC515-B72.jpg
The rear is home. I removed the brakes and I was able to get it to rotate freely. Ordered a shorter axle, brakes and rotors for it.
Hard to beat the ole 8.8. Everyone uses the explorer rear ends. I have one here for the S10 me and the boy are going to build later.
Gotta watch out for rusted axles tubes over the passenger side where they put a sticker. Seen a few rusted completely through now. Right by the leaf spring U bolt.
wow. this has gotten intense.
Going to drill 5x108 holes in the axles and rotors. I will have the machine shop at my work use a mill to center the holes in this 32mm 114.3 to 108 spacer better than I can with a drill press. I just ordered some drill bushings to match the stud hole diameter and rotor hole diameter.
https://i.ibb.co/bmLhLZ4/93-DB3-D03-...9-BADFB7-A.jpg
https://i.ibb.co/SXwYw4v/496-CFD4-B-...-CFC6344-F.jpg
https://i.ibb.co/cFbjf8K/C8-E13430-5...1323-EB6-F.jpg
https://i.ibb.co/txgGkPV/83-AABAB7-A...-B16-C99-D.jpg
I’ll try out my new drill fixture here soon.
In the last year I have been fighting with my boost issues to recently find out my intercooler was choking in the motor. The car is making the boost I want finally. Now to move onto bigger brakes and the 8.8.
https://i.ibb.co/tq26jqY/B37556-EF-F...51-AB9-BE4.jpg
https://i.ibb.co/dKH7JZk/698081-F1-6...AC6-B934-C.jpg
https://i.ibb.co/0m6Fx8g/E7-B96104-9...2-D9-FDBD0.jpg
https://i.ibb.co/Rvg3kRY/FDBEDEDE-C1...-E91-E28-D.jpg
https://i.ibb.co/3CysfLF/4-BDA38-BF-...2-EF6-F211.jpg
Raising the rear up a bit. Car drops and is hitting the driveshaft in the tunnel when accelerating hard.
https://i.ibb.co/rGYGJbw/4-D09-F6-E0...59-EC9-D76.jpg
https://i.ibb.co/QMVHZBS/F0978-A6-C-...A15-FB2675.jpg
wow. that would be sitting low if you're hitting the ds on a hard launch. Cant wait to see it at the track.
