edited vid is 3 posts up without faces
it's telling me the vid has been removed by it's poster........
My Daddy never Spanked me that bad when I did something wrong !!! LMAO
No I didnt miss a gear. The tires was spinning so bad it was just hitting the rev limiter. We had another run that beefcake didnt post (go figure). It was short and sweet but I actually pulled on him over a car length after giving him the hit. We started around 60 -70 mph and it ended around 100. That was the only time my car hooked. Anything under 60 mph was pointless. The car just wouldnt hook. I didnt want to risk a 80-100mph spin out trying to catch up. It just wasnt worth it to me.
Ford Taurus FTW!
I must say, USMC's deffinitely being a good sport about this one, thats how it should be done!
Congrads Beef!:bigthumb
True but sometimes no traction is fun. Check this out. http://www.youtube.com/watch?v=LVty_XbRNcI
Where'd the video go???
not true,
after getting whipped 3 times, he kept begging for more, right before the exit the cars were goosed from like 70 to 100, and just like he said in his other post, it would hardly be considered a race
as far as no traction, on the 3rd run, his car appeared to hook fine i watched the original vid, and you can clearly hear the car run through 1 gear, shift, run through another gear and then either miss a gear or bounce off the limiter
The new video sucks, the original video told us everything. Even beefs face haha
Your full of shit! For one I started in second from the roll and two you can hear the car hitting the rev limiter almost instantly in second and when i shift into 3rd. Thats why I backed out. As far as goosing it, again you chose to let off when I was ahead of you after I gave you the hit. Its amazing each time I get a head of you, you let off the gas. That is twice now! I admitting you beating me the other races why cant you admit I pulled on you when I actually had traction?
:popcorn:
Its getting juicy in here.
Does anyone have some sticky tires that don't turn to stone when it gets below 50 degrees?:lol: Can USMC borrow them to settle this?
btw...I don't personally know either one of you two, so I could care less about taking sides, but when I watched the original video, you were pulling on Beef, you grabbed another gear and were still pulling, then the next shift you missed. There is NO way the car blew the tires off instantly as the shift was made into 3rd, or it would have had to been 4th by what you are stating in your last post about starting in 2nd gear.
Don't get all bent out of shape, it's just an unbiased observation.
i already said you beat me from 70-100 lol, whoopty doo, how many people race from 70 to 100, i gave you a roll race, you had traction the whole time and you ganked the shift, not my fault you lost,
lmfao
definately missed a gear, the cars were side by side, he looked like he was pulling maybe a tiny bit, albeit not a ton, shifted gears, still side by side, and on the next shift, baam
there was plenty of traction i have the vid here at work if anyone wants to watch the original,
i wish i had software to black out faces, i'd be more than happy to put the orig back up
If I had traction there is NO WAY you would even come close. You told me few weeks ago. You was at the track trying to beat your current record. Immediatly after you said that you said, "I dont think I will beat it because the cold has my tires as hard as a rock. Its going to be harder to get traction!"
How about round 2?!
no, i said i wouldn't beat it because my stock tires were 1 1/2 pounds heavier each, plus i had the seat in, and we hadn't changed anything in the car
the car had it's best 60 ever of 1.87 thank you
as far as round 2, i've done your race, now it's your turn to do mine at the track, i called you out, you wouldn't come, i finally took your race, and you lost
it's your turn to race my race
as matter of fact i did 2 of your races, stops and rolls in your element, again, my turn next
Thats it then we have a round 2! Woo hoo when and where is this going to take place?
i'll be there!
i dont see that mustang running in the 12's on street tires . so beefcake will win again
