Getting about 3 psi.
Did you make sure the fire cone was installed on the wastegate seat when you installed it to the flange?
I got the heads blocked off at the exhaust side. It’s building pressure. I have some air escaping the wastegate and some escaping my welds. I’m going to have to weld the exhaust more and figure out how to have it seat better or get different style wastegate.
Does it have any heavier springs you could put it in?
My 3400 stall arrived. I should be picking up an explorer 8.8 4.10 next Friday.
https://i.ibb.co/QcNNRJ9/2-F7-C50-DB...455-CB9-CB.jpg
Nice!
Is your car leaf spring or coils?
Gotcha. What all does it take to put the 8.8 in it? Same width?
I will have to buy a mount kit and shorten one sides axle. It will be 57” wide instead of the Volvo’s 55” width. I’ll probably get it drilled to 108x5 to match the Volvos pattern.
https://i.ibb.co/1KtpT04/2-D696413-2...-FC515-B72.jpg
The rear is home. I removed the brakes and I was able to get it to rotate freely. Ordered a shorter axle, brakes and rotors for it.
Hard to beat the ole 8.8. Everyone uses the explorer rear ends. I have one here for the S10 me and the boy are going to build later.
Gotta watch out for rusted axles tubes over the passenger side where they put a sticker. Seen a few rusted completely through now. Right by the leaf spring U bolt.
wow. this has gotten intense.
Going to drill 5x108 holes in the axles and rotors. I will have the machine shop at my work use a mill to center the holes in this 32mm 114.3 to 108 spacer better than I can with a drill press. I just ordered some drill bushings to match the stud hole diameter and rotor hole diameter.
https://i.ibb.co/bmLhLZ4/93-DB3-D03-...9-BADFB7-A.jpg
https://i.ibb.co/SXwYw4v/496-CFD4-B-...-CFC6344-F.jpg
https://i.ibb.co/cFbjf8K/C8-E13430-5...1323-EB6-F.jpg
https://i.ibb.co/txgGkPV/83-AABAB7-A...-B16-C99-D.jpg
I’ll try out my new drill fixture here soon.
In the last year I have been fighting with my boost issues to recently find out my intercooler was choking in the motor. The car is making the boost I want finally. Now to move onto bigger brakes and the 8.8.
https://i.ibb.co/tq26jqY/B37556-EF-F...51-AB9-BE4.jpg
https://i.ibb.co/dKH7JZk/698081-F1-6...AC6-B934-C.jpg
https://i.ibb.co/0m6Fx8g/E7-B96104-9...2-D9-FDBD0.jpg
https://i.ibb.co/Rvg3kRY/FDBEDEDE-C1...-E91-E28-D.jpg
https://i.ibb.co/3CysfLF/4-BDA38-BF-...2-EF6-F211.jpg
Raising the rear up a bit. Car drops and is hitting the driveshaft in the tunnel when accelerating hard.
https://i.ibb.co/rGYGJbw/4-D09-F6-E0...59-EC9-D76.jpg
https://i.ibb.co/QMVHZBS/F0978-A6-C-...A15-FB2675.jpg
wow. that would be sitting low if you're hitting the ds on a hard launch. Cant wait to see it at the track.
