Allows up to 15 seconds and then auto disables. You can release it prior to. Has a count down timer that starts once it sees the tires start to rotate.
Here soon I will have the numbers on my car. Pretty excited to see what she’ll do.
Going to be a big difference I bet. Cant wait to hear how it does!
604.63 SAE whp on 93 oct. I can’t wait to drive it!
Get on that 2019 list!
Great numbers on 93!
I was really hoping for more than 600 whp. Glad Brandon got it there safely. Last time there the car made 497 whp on the Ported blower. Hoping for 11s in street trim on the 555rs. He said the car could make around 700whp on e85 with the vmp so that’s always there for the future but I definitely want to enjoy this first.
Power seems right on the money for that setup on pump, no?
Pump gas 93, 11.8-12.0 af, 18 degree of timing and peak 19.8 psi with the 2.8 upper only. I had some belt slip up top. I may put my other belt on eventually since it was for a 2.7” pulley.
Going with a larger upper pulley for more contact and a 2 or 4 lb lower would help out Id think with the belt slip. That's still good though for 93.
Sounds about right for almost 20 psi. My Gen 1 Whipple/Lysolm/FRPP blower put down 535 at 16 PSI. Four more pounds of boost and a more efficient blower should yield around another 70 RWHP, which is right where you landed.
I probably wouldn’t of gotten 600 on the ported stock TB. Maybe a cool down run would netted more Horsepower then I got. Brandon cooled down my Eaton and got 497 out of it after making 488 pass. What was you WOT timing ended being?
My car at 19 psi on 93 made 599 on Adams Mustang dyno.
You guys got some big boost going on
Well said!!!!
After driving it I hope the axles stay in one piece,lol. I will need more tire for this.
https://m.youtube.com/watch?v=QFTaDQawNIQ
Gonna need axles and slicks!
Actually I ran slicks for Years on the car at the track. I could do 4000-4500 clutch drops with them having 1.6x 60 ft runs. I sold them when I stopped drag racing the car. It’s actually safer on the axles. Wheel hop, loading and unloading causing the axles to bind breaks them. Slicks keeps the geometry right and softens the blow on them.
You're gonna need em.
Now just waiting on that warm weather to get it out Im sure! Have you had a chance to try it at all yet? Sure its a completely different car.
I blipped 3rd at 60 and the tires spun. The boost is instantaneous. I’ll wait for a warmer day. What I’m really enjoying is the drivability. The car idles nice and drives well. So far my favorite part. This is probably my favorite setup on the car this far. I’m glad the LFP Tb idles down and doesn’t stick.
Nothing worse than a sticking throttle body... My Accufab on the silver Cobra stuck from day 1 and I hated it...
My dragon would idle around 1500-1600 rpm sticking. Sent it back to manufacture 5 times. Best it would do was 1200 rpm and sometimes stick. I traded it on a ported welded stocker. I ask for years what people had the least problems with on the Cobra. The LFP and Gt500 by VMP had best results. I was very hesitant to buy one though.
I kept my stock TB when I put on the Whipple I know I'm giving up some HP, but it drives and idles exactly like it did the day I drove it off the lot brand new- just with another 200 HP under the hood.
You can’t go wrong with stock TB. I’ve had the best luck with them. Hope the LFP treats me well.
3.14xR^2 = area of a circle. valve stroke is not linear whether you are controlling flow of a liquid or gas state of matter. So as the opening metering maximum flow gets larger the more critical control of the flap position becomes. makes sense why the OEM TB would be the better option. I am battling that question as well before my next retune.
80mm on 2011up
Dual or single?
Lol, single
They are rated at 1183CFM at 28” of. The 03 Cobra twin 57mm is rated at 1089 at 28”. You could probably get rough estimate on draw through supercharger system. Your probably better off seeing before and after on similar builds. Too many variables to see what kind of restriction you would have. I would think you would be fine around 600 whp on draw through system just based what I’ve seen on Cobras. Still that is just guessing. What have you guys seen on 5.0s with the stock Tb power wise on which supercharger?
It might be 0 degrees outside now but Sunday is going to be Sunny and 58. I’m going to finally get a chance to drive my Cobra.
Sorry no videos, the car would make the tires light up on demand in 1st and second. I could even ease into it and break lose at 60 in second. Third is a safer gear. I’m surprised they make cars from the factory with more power than this. I hope the owners who buy them know how to drive them,haha.
Good to hear you are out enjoying it!
I cant wait to get mine back out come spring. May have another one out too. Just a lot slower!
