^^^ next step....AWD? LOL!
The rear is welded! So glad I had a professional do it.
https://i.ibb.co/41P0WcD/40-C00368-6...A8327-CBF1.jpg
https://i.ibb.co/PZ13hNh/43166-B80-8...AE124-F1-B.jpg
https://i.ibb.co/FHBTWHY/06-A3-B197-...-B28-E8-C3.jpg
Don't forget adding a matter anti/matter containment system for safety sake. WHOOT!
progress is always good.
Nice!
What gear did you end up going with?
The new rear end ended up fitting in over the weekend.
https://i.ibb.co/n69YZh3/A0-C4-C827-...F052-B76-F.jpg
https://i.ibb.co/88qvpkp/3-B57-D9-E6...-F08-DF2-A.jpg
https://i.ibb.co/bRrN8ND/D9-B1-A6-D0...-D0777-B80.jpg
Look'n good! :cool1:
looks great Joe!
Thanks guys!
Did some work yesterday and tonight. Working on adapting the Volvo parking brake cable to the Explorer rear. Also decided to clean up my 20 year old aftermarket rear swaybar.
https://i.ibb.co/CzdHgLJ/08021751-A0...-B8-A817-D.jpg
https://i.ibb.co/1qkDBJc/C2-CA90-B5-...88466-EBE1.jpg
https://i.ibb.co/4YRttGK/7-D090352-6...6095-FFB08.jpg
https://i.ibb.co/2cP4b40/F21925-B7-C...914-FBCEB8.jpg
https://i.ibb.co/NtmYMH6/B2-E47-C80-...6-AECDEDE9.jpg
Making progress, I’m turning a mount under the car into the driveshaft loop mount. I’m having a bit of trouble with a brake line the front passenger side loosing up. Hopefully I get that figured out this weekend.
https://i.ibb.co/dcrkHZv/C65941-B8-6...FF969-DE78.jpg
https://i.ibb.co/wMz3bw9/132-ECB02-0...642-D61-EF.jpg
https://i.ibb.co/prsyC9b/C16-BE98-C-...1-F6-CCCF8.jpg
https://i.ibb.co/Mf82Nm4/9905-C6-BC-...6-F9-CC1-D.jpg
https://i.ibb.co/q5mtnjp/EF1-EBCA7-1...-ED635-BBD.jpg
So when will this project be under its own power and ready for the track?
I got the brakes pretty much done. I ordered a 6mm ID clear hose because the bleeder screws on Wilwood are much smaller than the bleeders on any of my other cars I have tubing for. I’m also going to adapt a Camaro driveshaft loop to my car. Probably will have to cut and weld it. Tomorrow I’ll be dropping off the driveshaft to get welded and balanced for the ford rear.
https://i.ibb.co/Xy090GR/B9-D49523-F...-D29-D4-D4.jpg
https://i.ibb.co/DGMQ5wC/FE6-A4-AED-...-D2-E48-E0.jpg
https://i.ibb.co/9hnNp8y/0031-D127-9...0-A66168-C.jpg
how to share album on facebook
