It Will Get There .
It Will Get There .
Yeah, it will eventually again. Lol
Tore it all back apart to clean up the wiring, install the Grant steering wheel, Grant quick release and install the MSD Power Grid ignition controller.
And paint the roll cage behind the dash, then get it running again prior to installing the NOS.
http://i1096.photobucket.com/albums/...pszbrbp2fr.jpg
Ultra light weight dash I see!!!
Weight reduction level 5000
Removed the 3-Step and selector switches in place of this, should give me much more functionality with tunability and logging.
http://i1096.photobucket.com/albums/...psbesrxx7g.jpg
So I decided to relocate the relays from the trunk area and move them up front to be more accessible if needed.
So I mounted them with the terminal blocks on the backside of the panel for the ignition and switch panel.
It eliminates additional wiring running too and from the back and looks much cleaner.
http://i1096.photobucket.com/albums/...psqejjxsn0.jpg
http://i1096.photobucket.com/albums/...psmrinihvd.jpg
Got it back together and it runs once again, I must have done something correct with the initial set up on the Power Grid Ignition Controller. Lol
Now that it is running, time to get Chris to lay on that Sunset Pearl!
Why I decided to cut this up, is beyond me...
http://i775.photobucket.com/albums/y.../101194404.jpg
But Im sure you will have it looking great again!!
I will Craig, all in good time!
You still have that bike?
Im with Craig! Move that thing and get the coupe painted! It would look good!!
The E85Carbs.com conversion is complete, it still runs but needs some fine tuning. Can't wait to see how this Ethanol based fuel works for me! Lol
http://i1096.photobucket.com/albums/...psbin1kxt5.jpg
Do you have to run a flex fuel sensor? I'm curious how it would run on a winter blend vs a summer blend.
Out of the pump there is. Just have to test it to see where it stands.
I never test any I get. Mikey said he did at first but then just quit. Said there wasn't that much difference where he got it.
There is. We have seen anywhere from E65-E85.
You can always get this to test your E....
http://www.jegs.com/i/Holley/510/26-147/10002/-1
I know that there can be a fluctuation in the grade, is it really based on the time of year(summer-winter)?
