Kelly i have 3 2 1/2" 90 degree mandrel bends.It's not much but there yours if you can use them.Also some new 5 lug rotors.Let me know.
UPDATED PARTS LIST
Parts Needed
7/16 rockers
Pushrods(unknown on length)
Complete engine gasket set
Oil pump
Oil pan
Powerglide driveshaft
31 spline 5 lug axles c clips
5 lug read disk brakes
5 lug front rotors and bigger brakes
Manual Rack and steering shaft
Misc gray interior parts Carpet door panels, seats etc
Maybe some aftermarket seats
Throttle Body
Injectors(60lbs) I think Mod Depot is working on these
A9l Harness and computer
And lots of other small things I will be adding later
I have 96 GT single piston front calipers (still worked when pulled 1 week ago), rotors (probally need turned), 96gt rear pads and rotors with about 300 miles on them. do you need one seat or 2?
I have a bunch of grey interior plastics parts and 1 good grey passenger side power door panel you can have.
What about a K member and some A arms??????????? Also what about the battery box you still need one or not??
Have a complete UPR front and Rear suspension kit on the way I also have the battery box covered.
We do need front struts and rear shocks though
I have my original stock grey carpet out of my coupe. I had Keith Decker clean it..don't look to bad. It just has a few cutouts for my 6pt bar. If you want it let me know..I'll get it dropped off at cincy speed.
Sure but I might want to pick that up I'm going to try to not clutter up craigs store with big stuff
I'll drop off what I got at Craig's either tomorrow on Friday afternoon
Im sure I have an extra A9L and a harness piece to turn a non mass air car into a mass air car. If you can get your hands on a non Mass air harness I'll gonate all if it.
brake parts are at Cincy
I have 2 used Cobra rear rotors you can have. They look like they are in good shape. You'd need the right brackets to run the thicker rotors though. Something off a Mach 1 or a 94-98 Cobra. The Cobra have the same rear caliper as a GT though.
Bump anyone else
F.Y.I as far as seats go. If you want something easy to install and fairly light 2000 cavalier seats bolt to the mustang tracks. They look good to. No one will ever know there from a chevy.
BUMP still need a lot of stuff the car must be complete and running before powerfest since the producers is coming to check the car out then
any help will go along way you guy's.if u can donate any money or parts please do,this is a really big project and we need all the help that we can get
