Get with me if you want that drop in setup from holley. I'll give you a great deal.
Got the front tires on the D-10's and put them on. Think they will stay on this car. Still need to get my back tires ordered yet.
https://live.staticflickr.com/65535/...37a6ef46_k.jpg20200816_194255 by Brian Mcwhorter, on Flickr
https://live.staticflickr.com/65535/...d8fbb47c_k.jpg20200816_194828 by Brian Mcwhorter, on Flickr
SEXY BABY! DEEP DISH IS DIRECTLY PROPORTIONAL TO LARGE BREASTS!
Whoa, those look SICK!! :cool1:
Sweetness !!!
Looking good!
Thanks Rick! I cant wait to get it back together and running.
I really like those wheels.
D-10s have always looked killer on a Fox. :cool1: Throw some 275/60 MTs on those rears and you'll be ready to rock!
The 255/60 does look a little small in there. The draglites were 15x10 with 6.5" bs. The Bogarts are 15x10 with 6 3/8" bs. Not sure how much that 1/8" will change things.
https://live.staticflickr.com/65535/...cd34b635_k.jpgIMG_20190209_165849151 by Brian Mcwhorter, on Flickr
Looks good, I just like the way the 275 fills the wheel well and the extra rollout, I totally get not wanting to beat on the inner fenders though. I'm sure the ET Street in 255/60 will work good too if you go that route. The D-10s should be fine since you've got rolled lips if you stay 255.
Id much rather have the 275 if I can get away without beating to much. Im not a fan of the large gap and I love how the bigger tire looks on them. I may have to just go for it.
Well I fired it up last night. Sounds pretty good. Needs some tweaking but it runs again!
Tires are on back order so those wont be here till the 21st I believe.
Needs tuned still but Id like to get this thing to the track once before they close.
Sounds good in the vid! Should run pretty good after you get it tuned. :bigthumb
I sent ya the pump I'd use if I were you on FB. It'll be plenty for what you are doing and it'll be fairly quiet. Those 60s will probably get you 500ish on E85 depending on the rest of your system.
Holley has a new drop in, in tank pump that is like 500 lph.
Make sure you have enough return line to return what's being sent back. Those pumps flow some fuel, right Greg?
Greg can tell you which pumps he's running but one is larger than the other. The big pump put out so much volume, that with a -6 return line, we couldn't open the regulator enough to get it down to factory pressure.
Just went to his thread and looked. The 525 pump is way too much pump for the factory lines, the 450 may or may not work but I'd be suspect
If it's a stock tank setup, I'd be looking at an aeromotive 340. I'm using two of em myself.
I ASSumed you were going with aftermarket lines since this setup comes with a billet aluminum hat that accepts an fittings. A 340 lph pump would be plenty for th hp on E85. Dave's turbo car used one and we never ran out of fuel pressure.
Same here, was thinking aftermarket lines too. Might just have to do the 340 for now and see where it gets ya.
Its on the ground for now. Still have to get a few things cleaned up yet.
https://live.staticflickr.com/65535/...0d83104d_k.jpg20201101_182607 by Brian Mcwhorter, on Flickr
https://live.staticflickr.com/65535/...8435633c_k.jpg20201101_182647 by Brian Mcwhorter, on Flickr
Yes sir, keep poking at it.
Finally touched this one again over the last couple days. Radiator is set in place and Im working on wiring the fans. Just picked up a Derale double relay set up for the Contour fans. Curious as to what others have wired them into for the trigger wire. I hate wiring!!!
Brian, I'm happy to see you chipping away at this again. Such a cool, clean car man. Can't wait to see it done.
I have contour fans on my car and I ended up using a Derale PWM Fan Controller. So far it has worked well.
They claim that it won't support the current draw of the contour fans, but I'm pretty sure that's a "playing it safe" claim. I ended up ditching the 50A circuit breaker that was supplied with the controller, and installed a big in line fuse link. (60 or 80 amps I think..).
Have had zero issues with the setup thus far.
Granted, it's definitely not a daily driver.. So I cannot attest to long term durability. But as far as the operation of the cooling fans is concerned, it is fantastic. Once I dialed everything in, the fans just work. I never think about them. It's nice. [emoji106]
Sent from my Pixel 5 using Tapatalk
Still working on the fan wiring. Of course waited on 10 gauge fuse holders for a week.
https://live.staticflickr.com/65535/...ae1f3bb8_k.jpg20210627_104013 by Brian Mcwhorter, on Flickr
Looks great!
Got the hood on but not yet adjusted. Ill get it painted eventually. HO Fibertrends 4 inch.
https://live.staticflickr.com/65535/...ddbad27d_k.jpg20210629_204926 by Brian Mcwhorter, on Flickr
Well been back on this one too. Decided that I wanted to keep the stock hood so I removed the intake spacer so I could get the hood to shut. Finished up the tranny cooler, radiator, and fans. Got it cleaned up from setting the last couple years and pulled it out for some pictures!
https://live.staticflickr.com/65535/...19b559ec_b.jpg20220518_141919 by Brian Mcwhorter, on Flickr
https://live.staticflickr.com/65535/...3b77313e_b.jpg20220518_141352 by Brian Mcwhorter, on Flickr
https://live.staticflickr.com/65535/...0700894e_b.jpg20220518_141627 by Brian Mcwhorter, on Flickr
https://live.staticflickr.com/65535/...9cd49831_b.jpg20220518_141237 by Brian Mcwhorter, on Flickr
Your favorite color Brian!!
