I love my Stage 3+. Smooth as butter while driving after break-in.
Are you trying to slip the clutch like the stock unit? I'm used to driving the regular Spec stage 3 and it is more of an on/off type clutch being a 6 puck design. The Stage 3+ grabs hard too but can be driven a little more like a stock clutch can. I had the very slightest chatter on mine in the beginning but a lot of it has to do with driving style.
I had the regular stage 3 with stock flywheel and now have the stage 3+ with aluminum flywheel. The regular stage 3 for me required a quick slip and then go. It never really jerked or bucked at low rpm unless you really tried to slip it a lot.
The stage 3+ is a dream of a clutch for being able to hold 800ftlbs. I'll let you try it out at the SBZ cruise if you would like.
I think that can be arranged.
heres my 2005 gt premium 5 speed!! i bought the car back in september so i dont have alot done but heres what i have: C&L racer intake,steeda udp's,jba axlebacks,eibach sportlines,gt500strut mounts,gt500 spoiler,roush window louvers.... also have a yukon 4.30 gear sittin in my garage getting installed very soon.
ran the car at edgewater on 4-17.... it went 13.85 at 105.29 with a 2.2 60 foot time, but it was my first time at the track lol and stock pirrelli tires and 3.55 gear . plans for the car are wheels and tires next,then kooks headers and offroad x pipe,then some cams..... hope u guys enjoy!!!
adam
cars look great guys
heres mine.... i have a 2005 gt premium 5 speed, its black on black. only had it since september so not alot done so far but a lil bit!
mods: C&L racer intake with 95mm maf,steeda udp's,jba axlebacks,eibach sportline springs,ingals camber bolts,gt500 strut mounts,gt500 rear spoiler,roush window louvers.... waiting in my garage to go in is a yukon 4.30 gear so hopefully that goes in sooner than later!
best 1/4 mile is 13.85 at 105.23 with a .842 r/t and a 2.320 60 foot (ive only run the car 4 times and they were on stock tires,and stock 3.55 gear)!
adam
Sorry didn't see your questions before. The ride quality wasn't really affected negatively at all. Along with the A-arms and k-member I also did the front swaybar delete at the same time. It made a nice difference in weight transfer. I did lose a bit of corning ability but nothing like you do in a fox body. If you don't do the swaybar delete then you will notices crisper turn in thanks to the poly bushings or spherical bearings on the a-arms instead of the soft hydro bushings in the stock a-arms.
Oh yeah and the car made 650/605 with a slipping clutch.
cant wait to see everyones ride in may
I already have a Steeda light weight radiator support designed to work with the sway bar so Im not going to delete the sway bar. I heard the K member with arms makes the ride a rougher than stock I was curious how much. I want my car to handle like a champ so I think I will make the purchase.
