Damn ..good luck with it man I'm sure it will come out next year quick as hell
Only time will tell lol
Not sure. Car shut off about the 900' mark. Tried starting it and it wouldn't crank.
Bad detonation? I've never seen valves sprinkled like that before.Was that from part of the cylinder bouncing around in the chamber?
Is it so bad that you wouldn't be able to rebuild with what you have?
The top land broke off and hot the top of the head. Assuming it shot out the exhaust. I'm not sure what caused it. The car ran for 2 years with more power just fine. I put a different blower on it and it blows within 100 miles.
I decided on which block to go with. I wanted keep the car numbers matching. I'm sending my block to ERL for a all aluminum 427ci 6 bolt block with 1/2" ARP head studs, dragon slayer crank, billet I beam rods and weisco pistons. Upgraded everything I could. I don't want to do this again. They claim they have cars with over 1800hp with this block. With a couple running 6's in the 1/4 mile. If you're familiar with the Ohio Boys or Ray Litz. This is the exact block they use. Still haven't decided on which 6 bolt heads I want to go with. For fuel I'm going with ID1700 injectors, triple walbro 485 pumps, controller, all stainless lines and fittings and all the wiring. This should be enough fuel to run E85 to 2000hp. Once it's done it should look like the block below. They have finished short blocks but like I mentioned before. I want to stay numbers matching. Another thing I've been thinking about is upgrading to a F1x Procharger. There's a quite a few Vettes putting out 1500+rwhp with a good combination. I'll decide once I add up all the parts. Im currently using the 3.33 pulley. It's biggest pulley for my 2200r. So im basically barely using it to its potential. The car ran 10.4 @ 104mph hitting the brakes before 1000' mark. I feel if the track would of been better and I ran a full pass. I would of had a 9 second pass.
https://scontent-lga3-1.xx.fbcdn.net...g=eyJpIjoidCJ9
That's going to be awesome. Better blower probably had more cfm and it went lean. I have a head that looks similar but I'll have it fixed and pop the spare piston in it.
If your going to buy new fuel lines, look into teflon lined hoses for the E85. Supposedly it's a lot better.
Good deal!
Sure is gonna be nasty!!!
When's the cage going in?
Great build! Was this a ls9 car to begin with?
Let's us know when you plan to run it again. I'd like to see it.
I have a allot to do. I'm also helping my dad build his Camaro. I should be finished by the spring shootout. The motor is basically ready to come out of the car. I'm just waiting on a hoist to lift it out of the engine bay. Then its off to ERL to get built. That'll give me enough time to run the fuel system and decide if I want to put a cage in it or not.
If your anywhere near Morrow you can borrow mine. Pretty sure I won't be using it anytime soon.
Just thought I would toss it out there! I was tired of borrowing my dads when needed so picked up a used one and engine stand myself. Pretty sure I've used it 2 times but nice to have around. Good luck with that motor, car is a beast!
I just got back from a 5 hour trip to ERL on only 2 hours of sleep. Now I have a 10 hour work shift ahead of me. It needed to be done though. Shipping was over $150 and it only cost me $10 in gas. She'll be a resleeved fully forged 6 bolt 427ci block in approximately 8 weeks. I'm probably going with Trickflow 255x LS3 6 bolt heads and use the LS3 intake manifold. I thought about switching to a LS7 style head and use a OEM LS7 intake. I'm not sure the power gain is worth the money though.
http://cimg7.ibsrv.net/gimg/www.corv...0c89357c48.jpg
What kind of power would it pick up over the LS3 stuff?
Been to ERL in New Albany many times. Had Luke one of their machinest's and Dale their head of maintenance in several of my training classes. Installed their 2nd CNC Laser as well. Toured the whole facility. Great bunch of guys. Very well known in the import and marine industry.
The LS3/7 heads flow so good. I wouldn't buy a set of heads if I wasn't switching to a 6 bolt set up. I remember looking at stage 3 heads for my 04 cobra and 3V and they didn't even flow close to these head in stock form. The place im buying them from flow tests them ports them even further where the drag.
Never in my life would I imagine myself spending $5,000 for a fuel system. It should show up any day now.
Fore Innovations C6 Corvette stage 3 Fuel System
-Triple Ti Auto 267 (Triple 485's) E85 fuel pumps
-Billet hanger
-Billet fuel filter
-10 micron stainless reusable element upgrade
-Teflon -10 feed and -8 return hoses
-Black AN fittings
-Fuel pressure regulator
-FC3 staged fuel pump controller with hobbs switch (to activate 2nd and 3rd pumps)
-Wiring kit
-ID1700 Injectors
I also decided im going with a LS7 top end. I'll most likely be going with PRC 285CC heads and a precision metal craft intake. I still have alot of research to do before making my decision.
Haha, I'm torn what 100 dollars 255LPH pump I want to buy which I don't really want the spend the money on. Is that system designed to empty a tanker truck???
Its suppose to support 2000+hp on race gas. Its over kill but if one pump fails. The other two will be enough to support my power level. Last thing I want is a pump to fail and blow my motor. If Vortech/Paxton ever releases their new blower that'll fit the vette. I'll be upgrading my head unit. Its suppose to put out 1600hp. I'm just trying to think ahead. Who knows what the aftermarket will have for us in 5-10 years.
Good god!!! Sumbitch should run good though!
Just trying to keep up with you fast guys!
Haha Ive seen race cars with less power! Hell it ran good before the motor was hurt. Now it will be nasty for sure!
