It's gonna fly in that playskool romp around! Lol. J/k. I'm jelly, your's is moving along. I haven't touched mine at all. Busy on customer stuff.
Haha! I'm probably going to have an additional motor and transmission some time soon. Maybe I can wedge it into the cozy coupe! I just want to get it back on the road. It will be nice looking at a motor that isn't caked in 26 years worth of grease.
I decided to go ahead and get the stock 13mm rods resized and will get them back next week. Tomorrow I'm dropping the pistons off for rebalance tomorrow. I'll start putting the motor back together next weekend. This weekend I'm going to clean up the bores.
Your a machine! I wish I had your motivation!
I pulled the rods and pistons out tonight and removed pins from the pistons. So they are ready for tomorrow now. I ordered a ball hone that should get to my house by Sunday. I'm ready to start actually stop tearing things apart and actually start putting things together.
So I pulled the crank and found out the motor I got was a odd ball. I got the newer stronger block with the weaker rods. I'm really happy about this. The guy who sold me the motor was wrong about the block which is fine with me.
I took my first measurement after I reamed one cylinder. 3.783"
std piston range. 3.7795-3.7897.
Let's see how the others turn out tomorrow and after a good hone.
I took the borrow the tool at autozone ridge reamer to good use tonight. I'm going to ball hone this weekend and start putting the motor back together.
http://i963.photobucket.com/albums/a...psae24yiaz.jpg
http://i963.photobucket.com/albums/a...pse8egdfxp.jpg
http://i963.photobucket.com/albums/a...psjzgsawep.jpg
Looking good! You going to use your old rods and are they the stronger of the 2?
Next week I'll be getting back my block, rods, piston and crank from the machine shop. I couldn't get the ridge eliminated with hand tools. I'm really ready to get the motor back in. One thing I did a few years ago was reduce my compression from 9.8:1 to 8.5 to 1 by having my head bowl blended. I ended up getting oversized turbo pistons that will take it down to 8 to 1. They discontinued .024" oversized NA pistons for B230 motor so it was my only choice other than expensive forged pistons.
Good to hear!
Sucks you had to drop compression so much. Im sure you can make it up though with added boost.
Should be even more fun!
http://i963.photobucket.com/albums/a...psftjoh5du.jpg
Starting to put the motor back together. Crank, main bearings and piston assembly number one is in now. I'm planning on putting piston 2, 3 and 4 in tomorrow. Hopefully I'll have the bottom end finished this weekend.
Your on it!!! How does the new pistons look compared to the old? Still a stock cast piston?
The pistons look just like the old ones other than being little more dished. They fit so snug in the bore.Yes they are still stock cast but .024" oversized.
I got 3 of my 4 pistons in. I managed to snap a piston ring on piston 3 during install. I ended up having to buy another oversized piston complete assembly since no one carries them. I should get it early this week and start mounting various parts on the block. Today I repainted the block since when the machine shop cleaned it the ended up removing the paint.
Looking good! Sucks you cant just buy a ring set.
Thanks, I think I can get custom ones made. The dealer said it would probably take 3 weeks to get them. I didn't feel like waiting so I decided to just get a piston.
Don't blame you there! That's crazy!
The bottom end is finally back together. I'll hopefully start installing it into the car this weekend.
http://i963.photobucket.com/albums/a...psrkmn6vye.jpg
http://i963.photobucket.com/albums/a...ps4m5acx8b.jpg
That looks good!
Thanks! I just ordered another flex plate. The current one is missing a tooth. I guess I need to wait another week to drop it in.
looks to nice to put in that toaster with wings. Well done. How about a glass hood?
Haha Chad! Thanks. Glass hood??? No hood and saran wrap is much lighter and cheaper!
Looks sweet!
http://i963.photobucket.com/albums/a...pspoaok0ip.png
Check out bore standard. There is a bunch of wiggle room.
http://i963.photobucket.com/albums/a...psek4kck4d.jpg
Steamed cleaned my engine compartment tonight. It's not perfectly clean but it is 100x better than the greasy mess it once was.
Nice catch! Above there is a 96.00 to 96.03 mm spread which is 3.7795" to 3.8070" or .0012" spread.
The piston clearance is a lot bigger too compared to the AC125A. Wonder why that is?
I'm not entirely sure but I wonder does the diameter of the piston play a role in it?
http://i963.photobucket.com/albums/a...psefetz707.jpg
I had a short window before fiber to put on the new flex plate and lower the motor into engine compartment. I'll need to raise the transmission to line up the motor. Tomorrow I hope to have it mounted.
Good job!
Getting closer, mounted the crossmember, finished bolting up the transmission and put the head on today.
http://i963.photobucket.com/albums/a...psktzwsg4x.jpg
Making quick progress! I cant even get in the garage let alone work on something!
^^^ WHOA!!! HOLD ON THERE!! You have a garage the size of three of my houses. I've seen the photos. There's no way you filled that thing already. NO WAY!
