How cold of weather will they open down to?
I think it has to be above 50 degrees. Although 2Fast4You might want it a bit warmer so he doesn't do the 2 lane shuffle again. :)
:0
I didn't even blink an eye. To be honest with you, it happened so fast that I almost don't even remember it. Lol
That's good no one got hit. I had one time my Cobra hit a slick spot on the track going 100 and I remember letting off the gas because the car was going sideways. Not a good time. I thought it was 40F but I'm not sure close the track.
Well I'm glad you've been sleeping fine. I have been having nothing but bad nightmares since. I dream this big, fuzzy, gray, and calico caterpillar with glasses and a racing helmet keeps trying to bite my head off but I elude him and outrun him when he trips over the center line. :tongue2: :D
Once it gets down below freezing a few days with no warmth in sight, they shut it down. Cheaper to call it a year than replace pipes after they bust.
With all the rain the track might have flooded. Coming through Hamilton today you could barely tell where the lower dam was.
They just posted on FB that weather is looking good for TnT this Saturday.
Im done for the year, be back out next year.
packed away and sleeping. awaiting its christmas gifts.
Mine was out and about today, but i think the racing is done for the year at my house.
if the weather is good I am going out. I picked up a used set of 275/60/15's to try out to see if a 28" tire makes a difference before I buy a new set for next season.
I'll be heading down with Volvo. My Mustang is in hibernation. I almost bought a 2.3 whipple tonight for it for 1200 but timed ebay wrong. Maybe this time next year I can save enough for a new VMP TVS.
You'll be happier with the VMP Joe. Much more efficient, less heat, better flow. And the support from the guys down there is second to none.
I'll eventually get one most probably. I don't feel like dropping anymore money in the Volvo right now. I wouldn't mind running 11s on my nittos. 12.3 is best I gotten with them with the ported blower. Ever since dealing with and resolving my throttlebody issues I just stop messing with the Cobra. I'll probably just run a stock ported TB on my Cobra with a 2.3. Maybe a accufab if I can convince myself it's going to work ok. The Dragon was terrible.
^^^ You need to get that thing into the 11's or 10's.
It went 11.5 on sticky tires with a 2.8 pulley. I never ran it with the 2.7. I did drop .2 seconds with it on the nittos 555rs but I never been able to cut better than 2.0 on them. I don't want to get booted for not having a cage. Makes me want a 08 or newer car.
They warn you first to slow down if you make two back to back sub 11.50 passes. I got warned after two back to back 10.8x passes last year (2016). Didn't hear a peep from them this year running back to back 10.8x passes. If I get the car running solid 10's regardless of air next season then I will contemplate a roll bar. Hopefully the car's Christmas gifts will help with that in 2018. I love buying my car Christmas gifts.
I saw that Whipple has its Gen 3 2.9 out now!!!
Gen 2.
They got good deals on the gen 3 right now. It's a different rotor pack which is supppose be more efficient. It comes with 18psi pulley which is probably what I would run. You make good power with your gen 2. What is your setup?
Standard inlet with an accufab sbtb, ARH 1 7/8's headers, 3 inch x pipe, 80lb injectors, E85, 3.73 gear. Made 716/661 at 21lbs. 3.20 upper and a 2lb lower.
Id love to pick one up. Just not in the cards right now. Might wait to see some real life numbers before I jump on it.
I did not think you were running any nitrous over your blower. I cannot even imagine the immediate onset of torque with a PD blower and nitrous coming on at the same time. Add that to your stick shift clutch launch and your tires will be begging for mercy. Hahaha. I am sure the ride would be amazing when you get it hooked up though.
I would think it would help a lot. Also keep iats down.
I actually had mine out driving to run all the old fuel out. I plan on going tomorrow.
I plan to go tomorrow and make a few passes. I haven't been down the track in about four years. I'm excited. I bought us a family car 2012 SRT 8 Superbee Charger gonna play around in it . It feels pretty good!
I'm going to head down after two alternators and bunch of wiring changes my charging system is still not 100 percent. Not sure what's going on.
The track today was the worst I have ever seen it. I only managed one full pass pedalling the hell out of it and lifting early due to traction. I went 9.6, then lunched the blower again on the next burnout.
The blower grenaded so badly that the chunks flew out and trashed my hood too.
May be time to go turbo.
Damn man, you aren't having any luck at all...
I love Edgewater but their lack of prep kills it. They just don't care. Dick just keeps his hands out collecting money.
