You still have time! Get on the ball and get it done! I wanna see it out this year!
Get a strap and some lowering links for the bike and run some 1,000cc and under stock swing arm class.
Your correct Brian, I just need to keep at it and eventually it will be there.
Yeah you'll get there. Im sure your as anxious to hear it fire up as any of us are!
Finish get the engine bay rewired and replumbed and then see if I can hit 850hp and 1000lb ft tq
Probably nothing with Cobra. I'll probably get my 90 volvo into 13s this year and possibly add a Dana 30 locker to it.
If this weather don't clear up soon, Ill go crazy!! I have so much to do but I hate going out in the cold!
Well, I accomplished my first goal of my post, the Stang is alive and kicking and it is Nasty...
Now onto phase 2, get it to the track.
Probably end up buying another mustang. But first goal is to hopefully make some 9 second passes in the Eclipse.
I only ran my car 3 times last year due to work. Over the winter I have added a ton of power so I hope to get it out a lot this year. My main goal is to run in the 9.20 range in full street trim.
I've seen some of the work you have done. It's gonna be nasty that's for sure! It was impressive as it was though.
Thanks guys. Last year was devoted to nothing but work, but I took a new position that does not require working every weekend. The car is in the shop now getting the 8.50 cert cage. I should have it back next week.
