Thank you all! Just a couple more things and it should be all ready to go!
https://imgur.com/a/Dm5ZnZN
Time to not worry about the c4 anymore!
A little more progress!
https://imgur.com/a/aTNfndO
Looks good.
Steps
Looks a lot better I think on those wheels!
Finally a transmission
https://imgur.com/a/IbItgfX
I don’t think it ever ends
https://imgur.com/a/70KwroY
You sure got a lot done!
It has been busy since March. Dual boost solenoid setup on Co2 using dome pressure, behind bars aluminum tank, ethanol content sensor, new earls fuel filter, 35 spline gun drilled rearend setup, anti rollbar, new coilover springs all around, Fully built Aod-e, new derale trans cooler setup, wilwood front brake setup for 15” wheels, racecraft drop spindles. This past week was new arp chromoly exhaust manifold studs and trueing up the on3 manifold flanges.
Went from the 3” intercooler to a 5” today
https://imgur.com/a/k61uMzQ
I'll be interested in seeing what kind of IAT's you get with that 5" cooler. I keep waffling back and forth about an A/A.
If I ever actually get it out and get some data I’ll let you know
Do you still have the bumper in there also? Ive got the 3 inch in my red car and its pretty tight as it is.
Thought about that after I posted it. The LX does set back pretty far.
Man that looks good! Like it so much better with those wheels and how it sets.
What alternator bracket is that? Id like to move mine over to the drivers side too.
niiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiicaaa aaaaaaa
Thanks!! I’ll have to check with bracket it is
