I got lots of misc. pipe and mandrel bends for the hot side stuff. 2.25 2.5 3.0 3.5 and maybe a little 4.0 left.
i have two stock front gray seats let me know if you want them and where to take or meet some one to pick them up. (driver side rack needs replaced)
i can also get a lower intake gasket set (fel-pro)
We can use the bends if you have them PM me a number and I will try to meet up to pick them up. Pyskostang the seats would be great we want to run some cheap plastic buckets but money is tight on this project so we might have to use some stockers. Can you hold on to them from about 3-4 weeks and I will let you know
yea they are just sitting in my buddy's garage. let me know if u need them
I think I have the speed density harness. I am in Michigan right now but will be back in Ky on sunday. I have to check the trunk of the vert. I will let Kevin know and he will get it to you or I could bring it to Cincy Speed.
Keith
Thanks Kev. If you need anything else from the vert, just ask.
Keith
brake stuff is still up at Cincy. do you still need it?
Axles are here as well.
I checked on the PA belhousing, none of my suppliers sell it:(
I've got a new RCI red poly seat with a black and red padded seat cover and universal fit seat brackets for the car if you want it Kelly.
I have 1 Black Jazz bucket seat with black cover. And a couple cut up stock seat brackets. We could Use black dye paint on Jeffs seat cover and spray paint the back of the red seat black to match them. I still have some S.E.M. stuff to make paint adhere to vinal/ plastic.
Got the bellhousing today just need the adapter ring
BUMP Still need the adapter ring working on a driveshaft
interior parts
1.6 7/16th rocker arms
timing chain cover
timing chain
oil pump
throttle body
tranny cooler with an fittings
electric fans prefer to have two
Radiator
I think that is it for now and then its all small stuff
are you guys going to run a alternator
