Allows up to 15 seconds and then auto disables. You can release it prior to. Has a count down timer that starts once it sees the tires start to rotate.
Here soon I will have the numbers on my car. Pretty excited to see what she’ll do.
Going to be a big difference I bet. Cant wait to hear how it does!
604.63 SAE whp on 93 oct. I can’t wait to drive it!
Get on that 2019 list!
Great numbers on 93!
I was really hoping for more than 600 whp. Glad Brandon got it there safely. Last time there the car made 497 whp on the Ported blower. Hoping for 11s in street trim on the 555rs. He said the car could make around 700whp on e85 with the vmp so that’s always there for the future but I definitely want to enjoy this first.
Power seems right on the money for that setup on pump, no?
Pump gas 93, 11.8-12.0 af, 18 degree of timing and peak 19.8 psi with the 2.8 upper only. I had some belt slip up top. I may put my other belt on eventually since it was for a 2.7” pulley.
Going with a larger upper pulley for more contact and a 2 or 4 lb lower would help out Id think with the belt slip. That's still good though for 93.
Sounds about right for almost 20 psi. My Gen 1 Whipple/Lysolm/FRPP blower put down 535 at 16 PSI. Four more pounds of boost and a more efficient blower should yield around another 70 RWHP, which is right where you landed.
I probably wouldn’t of gotten 600 on the ported stock TB. Maybe a cool down run would netted more Horsepower then I got. Brandon cooled down my Eaton and got 497 out of it after making 488 pass. What was you WOT timing ended being?
My car at 19 psi on 93 made 599 on Adams Mustang dyno.
You guys got some big boost going on
Well said!!!!
After driving it I hope the axles stay in one piece,lol. I will need more tire for this.
https://m.youtube.com/watch?v=QFTaDQawNIQ
Gonna need axles and slicks!
