I can't wait to see it in person !!!
Thanks everyone! It’s definitely something I dreamed of doing since I was kid to this car. Back then it was either a 302 or even 340 engine. Thought Vopar would been a good name to replace Volvo with. Can’t wait to crank it over.
Old member on here years ago swapped a 302 into his Volvo. Mailman was his name. Havent seen him in years. Fell off the face of the earth it seems.
https://m.youtube.com/watch?v=H4UQAayVcXY
Making some progress again. Ran wire for the starter and located the hot wire in the engine bay.
Think I’m about three wires away from being done wiring it.
https://i.ibb.co/nPSWG3R/3-B5-C634-F...90-E275147.jpg
https://i.ibb.co/7Rg39nG/0-F32-AB3-B...09-A7937-C.jpg
https://i.ibb.co/gDkD8HN/79-D4-E1-A7...4-CC0-FFC1.jpg
I saw you have it cranking over. Not far from hearing it run now!
I’m going try starting it next weekend. I have to move a gas line over from the exhaust manifold and hook up the fuel pump trigger wire to the relay. Also pick a better signal wire. Crossing my fingers now. I got the new firm ware in the Holley terminator today. It was good seeing it turn on for the first time.
https://i.ibb.co/vv3wgKw/DA2-EB8-B8-...-DAECCACA6.jpg
Went to check the fuel pump and noticed fuel was flowing out of the back of the car. The return hose
needed replaced. I finished that today and got the car on the ground. Goal is to see if it will start tomorrow then I’ll clean the car up.
https://i.ibb.co/YtVhcGV/0-A533-C26-...23-C867-B2.jpg
https://i.ibb.co/XLwQ6rx/BB9-D9924-3...0-F1931667.jpg
https://i.ibb.co/6g9tcBZ/FD70-D024-6...D81-D43553.png
Ill be anxiously waiting on the video!!!
Here’s the first start video! I’ll start buttoning the car up but it was a good day for me.
https://youtu.be/ybU3kbb_Xbo
So close!!!
Is it just a stock 6.0?
Replaced the throttle cable today with an aftermarket one. Also added an adapter for the seam pipe to the radiator.
https://i.ibb.co/HpWShHc/0-DEAD2-DB-...-C319840-A.jpg
https://i.ibb.co/cxQWBhP/2-D5-B7-A25...48-A584-F9.jpg
https://i.ibb.co/JjwVQKK/04060129-72...EB23-E6-A7.jpg
Brought it outside for the first time to take a better look at it.
https://i.ibb.co/QCLcZKx/3-BA49-C59-...3-F8847-D0.jpg
Had to replace one fittings since I could get it to stop leaking. Ohio hydraulics is a great place to go.
The cam has more lope than I expected.
https://youtu.be/_VjbpIxNfkI
No more sleeper status! Sounds healthy!
I had pretty good leak coming from my transmission just sitting. I used a rubber gasket that came with the filter. Decided to buy a oem gasket. So far so good.
https://i.ibb.co/MCXgpBD/175124-BB-5...-D7-AB3-FB.jpg
https://i.ibb.co/w4LX7GG/197-A7-A04-...C60-EED998.jpg
First day out on the road.
https://youtu.be/IL1mEYFgjC0
Congrats, I'm sure it feels good to be driving it again!
