Your not supposed to be looking at the blower Aaron. Lol
More to follow soon.
New spacerhttps://uploads.tapatalk-cdn.com/201...e92f1ba0f2.jpg
Sent from my Z965 using Tapatalk
Had to weld a bung onto the radiator for the water temp sending unit. https://uploads.tapatalk-cdn.com/201...0c8d41d3ca.jpg
Do you run a thermostat?
Nice! You running that under the nitrous plate or are you planning on running a fogger?
There is no thermostat housing on this intake, each water jacket is ran with a -12 braided line. I can always install restrictors if needed. https://uploads.tapatalk-cdn.com/201...4e082f9743.jpg
Either way, it sure looks good!!
This thing has been sitting way to long!!! You have to be almost ready to make some passes!!!
Whats left?
I've ran into a couple issues, hopefully be able to soon.
You're gonna miss out on some good weather coming up!!!
Should've tried some flex seal!!!
Sucks though that it had to come back out to fix one small problem. Nothing is ever easy.
It was a bad leak, not sure anything would have helped other than replacing it. It was inevitable, it was easier to just fix it now. Just typing about makes it sounds easy, but when your car is only inches off of the concrete floor, it's another whole story. It should be out soon though.
Had some throttle linkage issues as well, I hope this helps. I couldn't get the throttle past 3/4 of the way, this will raise the point at which it was able to mount before. It also gives me a little more travel on the throttle, time will tell. https://uploads.tapatalk-cdn.com/201...ce3536e37d.jpg
