https://youtu.be/c2H_c8wLSGQ
First time actually talking about the car on camera.... and going over the build. It's a nice detailed look of things I have done. Now ready to make some hits!
Looks very nice Terry. Clean workmanship.
who would have ever thought that a blower with the displacement of a buick v6 3.8l would be sitting atop a 302 cid engine? the load (fill) at wide open throttle has to near or beyond 200%.
That car is really well done. Nice job!
I was looking at my puny 12psi 2300 TVS setup datalog on the 17 last night and at 7500rpm the load was 1.71 or 171%. I was thinking it was in the 120-130% range. So if there is any linearity at all in load to boost number relationship, Terry must be generating loads above 350% as you suggested if he is only running 25psi as Walter shared. Thats just mind numbing and unfathomable in my 'pittley' little world.
"Where does he get all of those wonderful toys?" Batman 1989
Thx for the shout outs!!!!
Boost is roughly 27-28lbs. The displacement is 327 CI because of the 3.8 stroke, which will change the equation some. And Thank You!
The injectors are 2600ID's and the size of stock injectors if you believe that. The just flow a lot more.
Your Welcome!
Beautiful car! Very well put together!
