Anyone have any thoughts on after market turbo kits? I’ve been researching and have settled on a 76mm single turbo kit from CX... planning to purchase in 1-2 months.
Have a link to it?
I have the On3 kit on the coupe I just bought. Seems to fit decent.
Cool, I looked at the on3 system as well. Here’s the link:
https://www.cxracing.com/TRB-KIT-MUSTANG-50-NEW-T76-IC
I'm sure it's fine for 2k. Keep in mind it will most likely will not fit, but if u got fab skills then ur good. Also you will want to upgrade parts as you go. That's a $100 turbo, $40 wastegate, $30 bov and $60 intercooler.
I have a honda tuning friend that has bought cx racing turbo stuff. It turned out very well for him. Pretty good parts for the price actually.
A coworkers son bought this kit and made 380whp in his cammed fox body body. I remember him not making power until later in the rpm band. Not sure if he had wastegate or Bov issue. I put t3/4 50 trim Ebay turbo in my 2.3 sohc Volvo and the power picks up around 3000 rpm. It would be much sooner with a 5.0 engine if setup right.
No actual firsthand knowledge of their kits but I've heard pretty good things about them. The turbos in particular but have heard good things about some of their kits too.
Cheap, fast or reliable. Pick two.
Do you know how much boost he was running to make that rwhp? The kit comes with an 8 psi wastegate, so the turbo will be able to make 16 psi max boost pressure. 16 psi should be able to double the HP output of the engine. Found this link that was pretty insightful on wastegate operation.
http://turbolabofamerica.com/what-si...spring-to-use/
https://ponydown.com/ponydown/index.php?main_page=index
That is who built my last turbo kit. I liked their work and would buy from again.
I'll sell you a complete kit with a precision 7675 gen 2 ball bearing turbo. It was built by Jason zimmers. Has precision gates and precision BOV. Comes with 2 downpipes and electronic cutout. 3800 for it all.
Damn good deal there!
- - - Updated - - -
Have any pictures of it installed? I have an On3 kit but that's almost making me want to upgrade!
Shoot me a text. 93seven 790 051six
