Ill be picking up the rear end from Rob on Sunday. Then to get it in, plumb the brakes, adjust the control arms, and get it down on the ground rolling. Another step closer!
Moving along!
Sounds great Brian. Was a little disappointed to see a carb on it, but whatever it takes to get it back on the raod.
Probably slow it down putting efi on it
If the only difference is efi, it will pick up slightly.
Picked up the rear end from Rob Lewis on Monday. Stock fox width, 31 spline track loc, 4.10 gear, Moser carrier studs, axles, and girdle.
I have new brake lines to put on yet along with the North Race Car caliper brackets. Hope to get it put in this weekend and get it on the ground. Have UPR uppers and lowers with Team Z drag springs.
https://live.staticflickr.com/65535/...0fa96f1d_b.jpg20211106_145751 by Brian Mcwhorter, on Flickr
https://live.staticflickr.com/65535/...3561356f_b.jpg20211106_141204 by Brian Mcwhorter, on Flickr
Anyone ever dicked with North Race Car rear caliper brackets??? Not sure what I have going on.
I ordered the NRC brackets for the 94/95 GT rear brakes. Also ordered the Moser axles for fox length with the brake register for the rotor. It looks like Im about a half inch short from getting the caliper bracket to line up with the rotor. They give you a spacer and some washers but I really need 2 of the spacers to make it close. Im sure its something Im doing wrong.
I've installed a bunch of them. My red rocket has them on the rear with cobra brakes.
I called them up yesterday and I talked to Richard for probably 20 minutes. Seems like a real good guy. He said I can space them out as far as I need and he has another set of the 1/4" spacers in the mail. Now just to find longer bolts.
Weird that its supposed to bolt up, but needs a bunch of spacers.
Still working on getting the rear end finished up and installed. I need to start running brake lines now.
Picked up the new master cylinder. Have to get it on along with the MM manual brake conversion. Then to figure out how to run the brakes lines, line lock, and proportioning valve and residual pressure valve. 2 port 94/95 master cylinder.
#Slacker
:D
You aren't kidding! Man Ive been busy as hell lately. Seems like as soon as I get one car fixed, Im moving on to another only to circle back and work on the others again. Cant get caught up!
Hopefully I start making some progress soon. Id love to at least see this one on the ground in the next week or so.
That rear end looks great! I’m still in the hunt for a 8.8.
If I come across any, Ill let you know.
Rob does great work. If you need one done, he is the man!
