Is your shifter backwards?
https://i.ibb.co/VVx9yBz/716-C92-CA-...-E8-EC2-B8.jpg
I thought the same thing when I laid it in there but it is the right way,lol.
Yes, an auto shifter. In my coyote coupe
It looks like the lock out lever should be on the front.
This great news btw!! I can cut into the dash and let the new shifter clear the ebrake!
I’ll just cut into this compartment. It will sit pretty good in there once this is done.
https://i.ibb.co/Lr22B83/7-B7907-BE-...2-D6-F2-AD.jpg
https://i.ibb.co/pjsPjfv/A62750-D1-D...05-F5-FA27.jpg
https://i.ibb.co/CmzDWyY/97-FB828-C-...F294168-CE.jpg
Made little bit of progress. Cut the dash to clear the shifter body and cut the coil bracket and test fitted the coil next to the brake booster. I broke a coil when I put the motor in. I didn’t realize it would clear.
https://i.ibb.co/PYf4y94/1-C4-A5-F85...93-C9-F1-C.jpg
https://i.ibb.co/60ngBfM/7476-F0-AD-...263-E20071.jpg
https://i.ibb.co/4WG9Mws/71-D71060-A...2-D28117-D.jpg
https://i.ibb.co/D99b812/2-D9-EE3-D3...A05-D7-F78.jpg
how to send multiple images in an email
Making progress!!! Looking good! What intake will you be running?
Probably just a filter on the end of the Turbo.
Yep, That's what I meant.
Just a factory LQ4 truck intake manifold. I think it will work fine with what I got.
New transmission pan, gasket and filter. I hooked up the shifter cable and the shifter is now functional.
https://i.ibb.co/nmDpVtQ/2279-D053-F...935157-F89.jpg https://i.ibb.co/8DtrFrv/1-A289-AC2-...-D166-E746.jpg https://i.ibb.co/vQzy6tZ/960982-AD-2...33-C1-F6-E.jpg https://i.ibb.co/Hpfn7vC/8-DDFFC46-5...BE63479-F9.jpg https://i.ibb.co/kX3ZMc1/DA047275-9-...BAC9939434.jpg
I was struggling with steering shaft hitting exhaust manifold. I installed a smaller diameter steering shaft from STS machining and cut piece of exhaust manifold. It clears now.
https://i.ibb.co/17gM5gT/BF44-C3-D8-...F0-BBF4-F1.jpg https://i.ibb.co/WytnDVH/7-CDBC57-A-...-BFF5-DB56.jpg https://i.ibb.co/25SFgmq/4-DE66141-6...-EB9-AEFDB.jpg https://i.ibb.co/stGqm85/648763-E3-A...DDC4-C1-A5.jpg https://i.ibb.co/VVfZjDy/E9-AA081-B-...6-CEB8-B08.jpg
Nice work! You are making good progress! Be ready to run soon?
I’ll be getting my new driveshaft next week. Made little progress this morning. Hooked up the feed and drain line for the turbo. Found more interference issues.
https://i.ibb.co/xs08P27/FD83510-C-9...12-E6-C286.jpg https://i.ibb.co/CQ65c0z/03-E3-C61-F...-F39-B36-B.jpg https://i.ibb.co/LZjw2m0/E0687-D4-B-...BE34-A68-C.jpg https://i.ibb.co/R09Jzz5/11-B1-AA99-...2-B2595416.jpg https://i.ibb.co/k0SRG15/C9-C27-F7-C...72058653-B.jpg https://i.ibb.co/NWFrfHy/8-E87-E7-CF...-FF49-BB39.jpg
