Results 1 to 2 of 2
Thread: 67-68 parts have to go
    golden68mustang Guest
    JVC AM/FM radio with tape deck for 67-68 ford mustang.
    This radio fits in the original dash with no cutting required. the radio was installed for a short period but removed to put the original back in. The radio works fine, I still have the book and all the paperwork with it. $90.00
    RCI Drag Racing Fuel Cell w/ Foam and many fittings - $115
    This fuel cell was used for one year. It is the drag racing model with the foam in the cell to keep fuel from sloshing around. Also many fittings are included. Also see the Holley High Flow Fuel Pump for sale. $115.00
    Holley High Flow Fuel Pump w/ regulator - $200 (Harrison)
    Holley High Flow fuel pump with Holley regulator installed once, in box.
    $200.00
    Richmond 4:20 gears - $250
    Richmond 4:20 rear-end gears for a Ford 8” rear-end. Gear were used for 10,000 miles and removed. Ring gear was slightly meshed upon removal.
    Used 1" rear sway bar - $50 (Harrison)
    1” used rear sway bar was installed on a 64-73 mustang for 3 months and removed to reduce weight. Urethane bushings included. Pictures available upon request. $50
    Holley Carbs for sale 600cfm, 650cfm
    For sale
    1-holley 4160 4 barrel 650 cfm linkage secondary "double pumper" used for one year for about 3000 miles with fuel rail. Carb is still on car and running--$280
    1-holley 1850 4 barrel 600 cfm vacuum secondary not running but have rebuild kit-- $100
    "Ford" symbol splash guards $10
    Call me if you are interested or email me
    513-379-9849 cell
    mingesgc@email.uc.edu
    Dec 2006
    Hamilton
    54
    8"
    8" gears still available?
    CANT FIND'M FRIK'N GRIND'M!!!!!
