Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 116
Thread: Need parts for the Stangbangerz.com Pinks Build please help if you can
    Feb 2004
    Carlisle
    3,777
    I know this list seems very long but I'm listing everything we need and I'm sure we will come up with most of the things very quickly. I will update the list as we collect the parts. If you have something you donate need and want to donate it even though its not on the list we will sell the items on Ebay and use the cash to purchase what we do need.
    I Understand that most of these parts people will not have laying around to give away and I will be trying to get these donated from the manufactures but I just put the entire list up so if anyone knows any Vendors that they might be able to get it donated through.
    Needed Parts:
    MOTOR PARTS
    Mass Air Computer and Harness
    SCT Chip
    Throttle BodyDeal Pending
    302 aftermarket intake-Deal Pending
    Any type of aftermarket heads(deal pending)
    Rocker Arms 1.6 or 1.7
    Cam prefer an F cam
    Valve Covers
    Motor mounts
    Headers-Unequal length to make turbo headers
    MLS Headgaskets
    ARP Head Studs
    Stock 302 oil pan
    Valve springs for GT40 P heads
    Suspension
    Wheels and tires-Pending
    8.8 Rear end
    3:55 gear
    Driveshaft safety loop
    Subframe connectors
    Shocks and struts
    31 spline Axles
    Roll cage 6 point
    5 point racing harness
    Any type of brake parts Like disk brake conversion parts
    Upper and lower control arms
    Anti roll bar
    Transmission
    C-4 Shifter
    C-4 converter
    C-4 Shifter cable
    Turbo Parts
    T-70 Turbo
    Any type of t-4 turbo flanges
    Intercooler
    Any type of 3 inch or 2.5 inch tubing
    Fuel Components
    Braided fuel lines or pushlock hose
    AN Fittings for hose
    Aftermarket fuel pressure regulator for aftermarket fuel system
    A-1000 or similar fuel pump
    Fuel Injectors 42lb or larger
    Mass air meter for 42lb or larger
    Fuel Rails
    Fuel Filter
    Fuel Cell at least 5 gallon
    Ignition
    Aftermarket Coil
    MSD Box or similar
    MISC Stuff
    Aftermarket aluminum radiator and electric fan
    Gauges Fuel pressure,Oil Pressure,Tach
    Alternator
    Starter
    A Big thanks to the following
    Parts Already Donated
    1988 Mustang Coupe-CRC Automotive Carlisle Ohio (937)743-9826
    Fresh C-4-Kelly 89notch
    Reverse manual Valve Body-replica Cobra J Riley
    50 oz flexplate-replica cobra J riley
    28oz flywheel-93hulk Mark Riley
    Misc Sensors-89notch and 93 hulk
    46mm wastegate and 56mm Blow off valve-JGS Turbo
    Timing Set-93 hulk
    31 spline Traction lock-Brian IBstroken
    Possibly GT40p Engine Complete-Car Connection Ohio
    Misc Engine Gaskets-Mark 93hulk
    2013 f150 FX4 ecoboost
    95 Lightning-Vortech
    89 Vert-GT40-P Motor, Exhaust, 4.10 gear on Bullets
    99 Baja Outlaw BES 510bbc ATI procharger
    Jun 2004
    Carlisle
    2,013
    I have a battery for the car also.
  3. #3
    Mar 2004
    Milford OH
    1,313
    I have solid motor mounts, valve covers, and oil pan that I can donate !!!
    Let me dig around in the garage for some other parts.....
    Scott
    Scott
    93 Coupe
    66 Fastback
  4. #4
    Feb 2004
    Montgomery, Alabama
    3,458
    I got an oil pan. Tell me where to send it to.
    ~Carl
  5. #5
    Feb 2004
    KY
    3,845
    you are using a a 4 cylinder car right???
    I have the front and rear sway bars from a turbo coupe. The front bar is thicker and the rear didn't come on the 4 cylinders. I have both of those if you want them.
  6. #6
    Feb 2004
    Montgomery, Alabama
    3,458
    Quote Originally Posted by Black92LX View Post
    Don't need a front sway bar on a drag car...
    ~Carl
  7. #7
    Feb 2004
    Carlisle
    3,777
    Quote Originally Posted by Gearhead View Post
    Scott
    Cool I knew everyone would chip in to help build this car.
  8. #8
    Jan 2005
    Miamisburg
    2,653
    I also have a truck lower, If someone has a matching performance upper. I have a set of stock valve covers that my brother(tz250) can write script in the top with his cnc. I can probably get us a hook up on the rear end assembly.
    #12 2007 dirty dozen
    Victorious pinks Crew member
  9. #9
    Feb 2004
    Carlisle
    3,777
    Quote Originally Posted by ibstrokin View Post
    Good deal see what you can do.
  10. #10
    Dec 2006
    331
    I have stock springs and retainers from a set of GT40P heads, if they are good enough. If interested let me know and I will check pressures.
    I also have a set of fuel rails.
    PM me and we can arrange pickup/ delivery.
    Dan Badger
  11. #11
    Sep 2005
    trenton
    732
    black venom offers his welding services. he specializes in thin gauge stainless and aluminum and tig welding and he works in a machine shop, so he can get material
    Present: 2014 GT vert - Lund tuned, Frpp cobra jet setup, 3" O/R X-pipe, GT500 mufflers, BMR drag springs, 20x9/10.5 STR 607's
  12. #12
    Feb 2004
    Independence,KY
    6,584
    I know its not much but I know I have a nice autometer Pro comp ultra lite fuel pressure guage (0-100psi)that also has a bunch of braided line and isolator. I may have other stuff I'll just need to dig around and see what I have extra.
  13. #13
    Feb 2004
    Union, KY
    815
    I've got a 3.55 gear and some misc. 3" tubing bends.
    A.K.A. Ian Mullane
    Stangless...for now
  14. #14
    Mar 2004
    M-town
    461
    I have a fuel cell! Maybe some other stuff I let ya know!
    I'm back!!!
    #1 on dirty dozen 2007
  15. #15
    Feb 2004
    Carlisle
    3,777
    Ok little Update on the parts
    Fuel cell-Mustangoutlaw-Jimmi fields
    Fuel rails-Mustangoutlaw
    Roll cage and fabrication-Rigid Race Cars
  16. #16
    Feb 2006
    in your mom
    2,104
    Not that it helps out a bunch But I have a brand new boost guage u can have, who do I give it to?
    89 GT AUTO < WTF WAS I THINKING?
  17. #17
    Dec 2006
    Batavia
    2,182
    24 or 26 spline converter? I have an 8 inch unit that I could repair for it.
    Alan
  18. #18
    Feb 2004
    South of the river in gods country
    7,654
    I have a shifter and a core c4 to donate. I also have a set of oldschool slapper bars if you think they would help.
    Come get it
    Kev
    I love F bodies!!
  19. #19
    Jun 2005
    Cincy Ohio
    3,137
    *sends alan off to the garage and ebay to see what he can come up with*
    I love my crazy friends!!!
    Kim
  20. #20
    Mar 2004
    Goshen
    5,929
    Are you wanting rear discs? If you are willing to run sn95 length axles(depends on what wheels you're running) , I have disc brake axle brackets, dust shields, and brake line brackets. Might have some other stuff, let me check the shop on saturday and see what I have left.
    98 Cobra - Bolt Ons
    2017 F-150 3.5 EB
