Changing things a bit. Making a panel to mount under the dash to house the new Holley system. I'm trying to figure out a way to make it fairly accessible without having to pull the dash pad off the frame in the future.
Rick
Rick90lx@yahoo-dot-com
6.27625 liters of turbocharged goodness
That looks good
Hell yeah, that's sweet.
#12 2007 dirty dozen
Victorious pinks Crew member
looks great. love the panel idea for the holley stuff
Looking good Ricky! I just went through about 30 pages or so...
Hope you get some time to get this thing done soon.
Thanks Ken.
Been working on it as time allows, how's yours coming along?
Greg and I worked on the car today, shifter is buttoned up as well as a bunch of small stuff. I made a new plate that holds the Holley ECM and it's bolted to the dash bar of the cage. Been spending a lot of time playing with the Holley software, this thing is slick! Changed the old rear end pinion flange over to the 1350 Strange unit which was more of a pain in the butt than I figured but it's done. Measured and placed the order for a Chromemoly driveshaft online. Got some 1/8" NPT quick fittings for the Meth installed as well as a feed from the turbo to the wastegate.
I also ended up moving the starter solenoid to where the factory ecm was and it's wired. Filled the motor with oil and primed the pump. I kicked the starter over the other night, which was a cool feeling. Getting close!
Rick
very slow. It coming though. I have the whole undercarriage done, finally got all the rust out, and got everything painted. Got most of the suspension together, finally picked up the rearend and trying to get it together. Need to figure out a couple of other things and get some stuff to the powdercoater pretty soon, to get it back on the ground.
Slow going, working on small things. Zimmers has my overflow tank and I sent my new EFI harness out to be modified, it's not back yet. PST 3" chromoly D/S with strange slip yoke arrived yesterday and I got it installed. Hoping my harness will be in next week, It's damn near ready to fire.
Rick
Daymmm getting close there Rick ...
Aaron
F**K Photobucket !!!
Finally received my modified Holley harness back. I was going to do this one like I did the Accel harness but after figuring up the cost associated with doing it with these materials, It was the same cost but there was no time involved. That being said I just got it back 30 min ago and I'm pretty excited about the way it turned out.
This Mil spec connector is nickel plated and the wires are covered in Raychem's DR25 heat shrink and labeled. I think it's going to look pretty sick!
Rick
looking good man....
91 Lx coupe, Stock bottom end 5.3, ported 243s, 224r cam, Vic jr, csu blow through, msd 6012, 76mm, th400/brake....
who did the harness work?
See this is why my count is not up. Your last post on this thing was in December! I'm sure you have had something to post in the past 6 months....
Not too much really but it should start coming together quicker. I mounted those panels in the back like we talked about and have a lot if it wired. I'll get some pics up in the next few days.
Rick
