Originally Posted by
5.0calypso93lx
Also, when I'm in the lower rpm's, and I hit the gas pretty hard(this is with the clutch all the way out, brand new clutch btw), I can hear the engine rev up and it sounds very strong, but the car just won't go anywhere for a second, and then BAM, it takes off. Its like something isn't hooking up in the drivetrain somewhere???
I'm also having issues, where all of a sudden I can barely get my transmission into gear??
Do you have an adjustable clutch cable ?? It might be the cable is not adjusted properly, either the clutch is not disengaging completely when the clutch pedal is to the floor (would make it hard to shift or get in gear).
Or, when the pedal is at the top of its travel the clutch is not completely engaged - this would cause the engine to rev up when you get in the throttle.
If you still have the stock cable and quadrant in there, I would probably ditch it for an adjustable.....
Scott
93 Coupe
66 Fastback
