LISTING FOR A FRIEND WITH NO NET ACCESS!
1985 Buick T-Type less then 117k miles when I took the pictures with minor mods, exhaust, "Red Armstrong" 93 oct. chip, plug wires and hot wire kit with a walbro 225 pump.The boost has been turned up some to go along with tune on the chip, even with all of this the ole car still get 22-25mpg! The radiator and water pump are both new,the car has been repainted at one time and someone did a poor job of sanding some of the pieces and left sand marks other then that and the clear coat starting to come off the outside is near perfect. The interior is blue with a bench style seat and column shifter and a digital dash that acts like it has a cold sauder joint because some times it will just go nuts. As far as I know this is a 3 or 4 owner southern car ( I almost bought it myself ), with no rust other then some spot on the deck lid that is either just bad paint or a lil rust starting to come threw I am not sure.The headliner is sagging and the carpet is faded on the transmission hump. This car is located in Pinson, TN. I can provide you with contact info on this if you need. 11,000 OBO!
