I have a block here and when I pulled the heads off the block there are differen't casting #'s on each one of the heads.One says E5TE and the other says E7TE. What is the difference here?
911 - Government sponsored Dial-a-Prayer
If guns cause crime, then pencils cause misspelled words
https://youtu.be/apTCdfr0bn4
347, AFM N-91 cam,TFS FAC 190's, Quick Fuel 750 carb, Parker Funnel, 4.30 and E-85
2011 UMTR Street Stick Points Champion
2012 UMTR Quick Stick 4th Place(Points)
2013 UMTR Quick Stick 2nd Place (Points)
2014 UMTR Quick Stick 2nd Place (points)
I remember reading somewhere that the heads were identical other than the casting number, but personaly never seen any real proof of it. The e5 was an 85 casting date code and e7 was the head used on 5.0 mustangs from 87 to 95(?). Im sure it appeared on other engines of that era as well.
Personaly, I would ditch them both and buy a better set.
I love F bodies!!
Well my other option right now due to budget is a set of GT40P but I have BBK long tube headers and I think there is going to be an issue with spark plugs. So well see I appreciate your input
Check for sure, but I think the long tubes will work with P heads.
I love F bodies!!
I recently did a head gasket and while i was at it i put some freshened up E7s on my stock '85 block that still had the E5 castings....and i couldn't see any difference that was significant enough to see with the eye. There is however a difference in combustion chamber size, as the '85 has something like 8.5:1 compression or something and the '87+ came in at around 9:1. It's minimal but if that's all you've got at least it's something. I think the headers will work also, i know MAC long tubes work and i think the BBK are basically a better quality version of the MACs.
-EVIL SSP-
'85 Kentucky State Highway Patrol SSP Coupe
362hp/364ft-lbs Tuned by Cincy Speed
http://www.cincyspeed.com/
Walk around/exhaust clip
The Stang
The CVPI
-David
