We finally got the Cobra out for an extended period of time yesterday to get an alignment done and start to figure out some of the bugs. Just curious as to what the Water Temp, Oil Temp and Oil Pressure should be running at? We are idling around 50psi and went acceleratoring it jumps up to 60, which I would think is about right? The water temp/oil temp hovered anywhere between 75-80C (167-176F). Just wanted to make sure we were in the clear with those numbers or if it's running a hair hot? Thanks guys!
