Back in late 07 I put on a Canton PS resevoir.
I noticed since then (could be a coincidence) that I have a very slight leak. Last summer/fall I made sure to tighten everything up and thought all was well.
I started the car up for the first time in 3 months yesterday and let it run for about 20 mins in the driveway.
I pull it back in and notice a slight leak. I jack it up and notice a tad of fluid forming a drop off of the power steering pump fitting, where the hose/spring clamp attaches. That clamp is damn tight too..so I wouldnt think that would wear out, but maybe I am wrong.
Also, it seems that a few of the metal fittings/couplers, where some of the rubber lines attach..its wet there too..now this could have been from a fluid spill I had last year..but I wouldnt think those would go bad.
I just started it up and let it run, and it formed a drip at the pump, right where the rubber hose/spring clamp goes on.
I even double checked to make sure I used the right fluid (mercon atf)..and I did. Just find it wierd that all my fittings feel wet and its leaking from that spot
