When you turn the overdrive ooff via button,it will stop shutting and vibrating.What is causing that when the overdrive is on????
D.S.S. Pro Bullet 331.
#13 Spring Street car shootout.
Big thanks to:
S&M Motorsports tuning and Fab.
Cincy Speed.
Hyper-Performance Motorsports.
Killer Koatings.
My other place.thestaginglane
the OD band may be getting loose or the OD servo may be getting stuck and not engaging all the way. Does the OD light flash when its starts shuttering?
I have no idea.Its my brothers car,and he's about as sharp as a gummy worm when it comes to cars.
Big thanks to:
Cincy Speed.
Killer Koatings.
Ask him if it does. On my Explorer when the OD light blinked that ment problem in the computer. Its like a check engine light for your tranny.
Does it do it only right around 45 mph?
I can "Visualize Whirrled Peas" - thanks for the ride Vinny, it was much too short!
-- Dave
Resident Philosopher
Pretty much when ever the car is in overdrive,it shutters and vibrates.Then you click the button and it goes away.It will be here this weekend at my shop for me to do U-joints so ill take a peek at it.
Big thanks to:
Cincy Speed.
Killer Koatings.
yeah sounds like the band or servo.
there are alot of posible causes for that problem get the codes and let me know what they are
[SIGPIC][/SIGPIC]work hard to build them so drive them hard
Will the codes be present at the OBDII connector,and can i pull them with a regular scanner?...Or do i need the damn ford WDS system?
Big thanks to:
Cincy Speed.
Killer Koatings.
should be present with normal scanner
I had the exact same problem with my 4r70w. Do a complete flush of the tranny (converter, lines, everything). The 4r70w has a heat issue that burns the fluid and causes the slipping. As soon as I put all new Mercon V in it, and a new filter (which costs a ton, well for the fluid anyway), it shifted perfect. Its a pretty common problem.
The TC has a drain plug and you can access it through the bellhousing.
Good luck.
In most cases this is converter shudder. Lucas makes an additive that will fix it most of the time.
http://www.extremeautomatics.com
Lonnie Diers 937-379-2233
87 Buick GN (in the paint shop so long not even sure I own it)
Yea i have flushed it twice since he has had it in the 2 years.I have replaced the engine once.It ended up being 1 missing and 3 loose driveshaft bolts.good thing i caught it.
Big thanks to:
Cincy Speed.
Killer Koatings.
