its on a 96 gt.how can you tell when these go bad?? it has a rough idle like a vacuum leak but when i take the vac line off and cover it with my finger the rough idle goes away and it idles at around 900rpm where it should.with the line on it idles between 500 and 700,just depends.also what should fuel pressure be at idle with and without vacuum??? Thanks guys
