Results 1 to 5 of 5
Thread: Need wheel help.
    Feb 2006
    411
    Need wheel help.
    I am getting a set of draglites this weekend. I need to purchase tires for the back set. They are 15x8 w/ 4.5 back space and will be mounted to a 86 stang with no massaging. Nor do I want to massage it. I thought someone told me a 275 50 will fit without issue on an 8" rim but not on a 10". Is that right? I don't want any rubbing at all. Also if I have to go with a 255, is there anyone still making a 255/50-15 drag radial? I know summit doesn't have anything. Only 60's. How tall is that in inches? I am hoping Ican run a 275/50-15.
    Justin
    86' GT 475rwhp 483rwtq
    Thanks to the tune from Precision Autosports
    Foxxx5oh's Avatar
    Foxxx5oh is offline ˙˙˙pןɹoʍ ǝןʇʇıן uʍo ʎɯ uı
    Feb 2004
    Louisville, KY
    1,568
    http://www.miata.net/garage/tirecalc.html
    that will give you heights and widths, i hope it helps
    ʎpuɐ sı ǝɯɐu ʎɯ
    1992 K1500 Suburban, not quite stock. -- 1996 GT Vert, mostly stock.
    Quote Originally Posted by 85_SS_302_Coupe View Post
    Some of us are confined by the boundaries of such things as common sense, logic, pride and even peer pressure and political correctness. This guy is clearly much less confined than i am.
  3. #3
    Feb 2004
    Cincy
    4,679
    I had 15x8s 4.5 Back Spacing try to keep the tires shorter or you will have problems with the tires rubbing the fender lip. I had 275-60-15s on mine. (28x9") I would try to find a tire that was close to 26" x 9"
    I wish my lawn was Emo so it would cut itself...
  4. #4
    Feb 2004
    Cincy
    4,679
    a 275/50/15 would be a 26x10.5 a P255/60R15 would be close to a 27 x 9 tire You still might need to massage the fenders a little but I think they would fit decent Check out http://www.mickeythompsontires.com/s...ETStreetRadial for fit
  5. #5
    Feb 2006
    411
    So 5.5" is the back space I need? That sucks because these wheels are mint. I thought for some reason it was 4.5". I guess I'll have to get my deposit.
    Justin
