my back 2 header tubes on the passenger side are getting to hot,i have replaced my head gaskets,heads,water pump,radiator,thermostat,and flushed the cooling system.I am still having the same problem,all the gaskets r on right and sealed good with no leaks.I'm running a stock fuel injection pump with a regulater thats bringing it dowm to a little over 6 psi of fuel to the carb.My fan is on a toggle switch that is on constant.This issue is causing my car to slowly overheat and is very annoying to boot.Somone please help.
