I've started to notice a few fuel symptoms recently on my car, and I knew there was a problem when my fuel filler cap light came on yesterday.
At first, I started to notice a fuel smell coming from my car and my g/f mentioned it as well since she was always on the passenger side.
Then a few days later, I decided to fill the car up like I always do. I always just set the handle on the pump, and go inside and pay, which I know is probably a bad idea. Well, when I went back outside to the car to hang up the pump, that's when I noticed a pretty good sized pool of gas on the ground under the car on that side. I looked around the filler neck on the inside of the fuel door and nothing was wet. The quarter was perfectly dry as well as the bumper.
I bent down to look underneath the car and that's where I could see fuel dripping from where the fuel filler neck goes into the tank. I couldn't really tell if it was coming from there as it was pretty wet and that was the lowest point. I just assumed that these cars shouldn't be filled up all the way.
And that's when my light comes on on my dash yesterday....
Is this a common problem on these cars? Anyone know if there is something I can check??
