Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: 92 "Gould 15" Mustang
    Feb 2004
    10,759
    It has 89000 miles on the body and only a few thousand on the motor. Also cover car for MMFF magazine March 2002
    It has a 347 built by Mike Bell at Dayton Performance. Here is the specs on it.
    Engine:Stock block, Align honed, Decked parallel with mains, Bored and torque plate honed, Coated cam bearings, Brass core plugs
    DSS main support, (block was align honed with girdle on) ARP main and head studs
    Probe forged steel crankshaft, H beam forged probe rods, Dished .030 forged SRS dished pistons, 9.5 cr
    Assembly balanced by Mike Bell to 28 oz, Complete assembly blueprinted, Moly file fit rings, Clevite 77 bearings
    Custom grind cam by Mike Bell for supercharger application, FRPP roller lifters, FRPP spyder and dog bone kit
    TFS pushrods, TFS Track Heat heads, no porting, TFS black valve covers
    Chrome dual sump oil pan and new pick up, Melling oil pump, ARP oil pump driveshaft
    Racemaster balancer, Racemaster billet gear double roller timing chain
    New timing chain cover from Ford, New water pump FRPP hardened cam retainer plate, ARP cam bolt and Crank bolt
    Cometic Head gaskets, FelPro gaskets everywhere else.
    It also has Edelbrock Victor 5.0 upper and lower plumbed for a fogger and BES ported, 75 mm throttle body, 42lb injectors, Pro Flow 85 mm MAF, Comp Ultra Gold 1.6 rockers,
    BBK cold air kit, MSD Pro Billet Distributor, and Spec Billet flywheel. It made 341 hp and 381 ft lbs N/A and has run a best of 12.06 @112 so far.
    I have only had it to the track 1 time so far and made 2 passes. The body has a 3 inch cowl hood, Saleen wing, Cobra grille insert, and GT40 rear bumper cover. Full cage inside with ARC switch panel, 85 GT Mustang
    seats, full grey interior minus back seat. Battery is in the rear in a sealed Moroso battery box and is a new Exide Orbital battery.
    The fuel system is all Aeromotive with A1000 pump, 2 filters, and A1000 regulator and all 1/2 push lock hose and fittings.
    It also has tubular K-member, Eibach Drag Springs with airbag, subframe connectors, driveshaft loop, aluminum driveshaft, aluminum radiator
    with electric fan, Competition Engineering struts and shocks, 3.73 gear, 1/2 studs, BBk long tube headers, X pipe, Flowmasters, solid motor mounts,
    and a bunch of Auto Meter Gauges and a 5 inch tach with shift light.
    It is on 4 lug Weld Drag Lites 15x3.5 front and 15x10 rears with new ET Streets. It also has a Astro Performance T5 with UPR shifter.
    The car is not perfect and the paint is starting to show its age. There is a scratch in the hood and where the rear quarters was rolled the paint is chipped and it has a few others and it needs an alignment. It is a sun roof car as well.
    It has some "cold Start" issues and will be 100% before its sold along with an alignment.
    This is going on RJ after I take some new pics of it. I just figured you guys have seen it already and know all about it.
    $7000 obo
    http://stangbang.tripod.com/ Where all this began!
    http://stangbang.tripod.com/twisted/ Vinny
    1984 Mustang build @craig_btr on Instagram
    Feb 2004
    10,759
  3. #3
    Feb 2004
    10,759
    Whos good with Photoshop? If I cant sell this, I plan on getting rid of the stripes and stickers. (NO offence to Gould) They arent my style and if there is going to be a name on the Stang its going to be MY name...or Cracker Ass Cracker on there somewhere. Shit, why Im at it, I might as well get rid of the sunroof as well. And well SHIT, Im sure the cage needs updated, why not throw my 427 in it while Im at it. Holy crap, I can get some updated rims and tires as well. Trans, Im sure the T5 wont hold up to a 427 w/400 Shot either, so I better start looking. The seats and interior, ugggh!! Needs to be updated as well......
    FN Mustangs.
    Serious, who is good with Photoshop?
  4. #4
    Jan 2009
    Hillsboro, Ohio
    7,916
    It's sure making its rounds!!! I miss that car! Glws!!!
  5. #5
    Mar 2004
    Anderson
    2,948
    Post a good sized pic of the car and Ill see what I can do. You just wanting it the solid blue?
    2011 Black on Black GT
  6. #6
    Jun 2011
    Middletown
    546
    I love me some editing with photochop!
  7. #7
    Feb 2004
    10,759
    Quote Originally Posted by chris91 View Post
    I dunno...Have at it!!
    Quote Originally Posted by Gstang117 View Post
    Heres some pics.
  8. #8
    Feb 2004
    Montgomery, Alabama
    3,458
    Just my opinion Craig, but I think you should leave it alone. It is a one-off Gould custom and should stay that way. Just sayin...
    ~Carl
  9. #9
    Mar 2009
    Amelia
    3,026
    Quote Originally Posted by usafstang View Post
    x2 except for the rear bumper i dont like it but that's my .02
  10. #10
    Oct 2004
    1,307
    i dont think craig cares
  11. #11
    Jun 2010
    wilmington ,ohio
    1,283
    Not many goulds left around , I would leave it like it is . Im sure you can find someone to buy it. If i didnt want a 93 cobra so bad , i would be beating down your door to keep this car preserved like it is.
    87 T-Top gt(sold)
    93 Cobra (blk/grey)(sold)
    96 Cobra (blk/blk)(sold)
    93 Gt(put out to pasture)
    93 Cobra #4084(sold)
    2010 kona blue gt(sold)
    2013 ghig gt
    2018 kona blue gt
  12. #12
    Feb 2004
    10,759
    Pssst...the 90's are over.
    Quote Originally Posted by Pitbull1052 View Post
    See, I kinda like the rear bumper.
    Quote Originally Posted by mad max View Post
    I have a guy kinda interested with trading for an older Malibu, so we will see.
    Quote Originally Posted by dsmawd350 View Post
    This. Im looking at it as a 92 GT with some outdated Graphics on it. The quality of the graphics and paint are very good, but NOT my style.
    I think IF I keep it, I might bring back my BABB paint job.
  13. #13
    Dec 2010
    174
    i like the rear bumper.i would love to trade my lx for it but thats a long shot
  14. #14
    Feb 2004
    Montgomery, Alabama
    3,458
    I know, I know. That's why it was only my opinion and you know what they say about those.. haha. In the end, it's your ride and you will do with it whenever you deem fit.
    Now if you want, I will clean up YOUR for sale thread that we all cluttered up.
    ~Carl
  15. #15
    Feb 2004
    10,759
    Nah. I like the chatter.
  16. #16
    Feb 2004
    10,759
    I have a clean Ohio Title in hand, so someone make me an offer on it!!
  17. #17
    Jun 2005
    Maineville
    312
    Try Craigslist that's where I sold it!!
    1997 Cobra White
    1992 GT Gould # 15 Car
    2004 Cobra Competition Orange
    1995 Explorer 4x4 DD
    2005 F350 10" Lift My Latest Beast
    2004 Ram Crew Cab Hemi 4x4 7" Lift
  18. #18
    Feb 2004
    10,759
    Quote Originally Posted by blowncobra View Post
    Its on there.
  19. #19
    Jan 2009
    Hillsboro, Ohio
    7,916
    The more I see it on here, the more I want it back!!! What all kind of trade you looking at?
  20. #20
    Feb 2004
    10,759
    Quote Originally Posted by draggin50 View Post
    Clean Coupe or CASH!!
