about to pop the pistons out since i lost a head gasket and wonder what the best rings are to run with boost. i seemed to have a crankcase pressure problem and figure theres no sense in tearing the top down and not gettin the block checked and re rung at the same time.im not sure its a blow by problem and didnt get a chance to do a leak down on it before the head gasket let go unfortunately, but id rather just ring it while its apart. so... i used to run alot of juice in my big block and at that time hellfire rings were pretty good but that was 5 years ago. im running 15#of boost on this 306, but im also kicking around the possability of spraying it out of the hole at the track..probably 100 shot should get her motavated..lol let me know what you all think about the rings, and/or the idea of juicing it also...thanks
