Ordered a spring kit for the vacuum secondary, let's see if this makes a difference.... Should've went with a 650 double pumper
Nice progress. Looks real good.
Hopefully I tracked down the problem. I turned my idle mixture screws all the way in and nothing. Cars running really rich at idle. Time to track down a new power valve in the morning. Hopefully it makes a big difference. Hopefully someone has one in stock so I can run some TnT.
Went to TnT tonight. Best run was:
60' 1.747
1/8 8.487
1/4 13.280
MPH 102.42
Nothing to brag about, but it did better than I thought it would and it was my first time. I must say, I'm hooked. I'm already wanting that 12.999999.
Good on that, glad it's starting to work out for you.
Would switching from my 600 cfm vacuum secondaries carb to a 650 Double Pumper be beneficial to my combo? Also might go with 4.30s over the winter.
nice project. keep up good work!
It's been a long winter. Finally got to pull my junk out of the garage today.
http://www.youtube.com/watch?v=lZ-r_gtG1bk
Sounds good! Hope to see it out come spring!
Haven't updated in quite some time. I've found a few deals on some used junk and made a few changes. Bolted on a set of old Trick Flow Twisted Wedge 170 heads and switched to a new 650cfm mechanical secondaries carb. My main focus this winter has been drivetrain. My goal is to drive to the track and run on sticky tires without worrying about breaking. I acquired a TKO600 with CF dual friction clutch. I am also upgrading to a set of Moser 31 spline axles and 31 spline trac lok.
Nice parts!!! That should make a big difference!
I bet that will make a little bit of a difference!!!
Switching over to fuel injection also. Going with a stock computer and harness or an aftermarket set up?
I'm going to give Megasquirt MS3x a try.
Gotcha. Ive never ran the Megasquirt but there are people out there that like it. As long as it is fairly easy to tune, you should be good.
If you want easy to tune and simple to install check out thed stinger performance PiMP XS ecu I am running it in my turbo notch. Tunerstudio is really user friendly
1992 lx 5.0 5 speed stock and slow but looks good!
