Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 82
Thread: Project, about time!
  1. #61
    Apr 2007
    Independence
    482
    Ordered a spring kit for the vacuum secondary, let's see if this makes a difference.... Should've went with a 650 double pumper
  2. #62
    Aug 2012
    89
    Nice progress. Looks real good.
  3. #63
    Aug 2012
    89
  4. #64
    Apr 2007
    Independence
    482
    Hopefully I tracked down the problem. I turned my idle mixture screws all the way in and nothing. Cars running really rich at idle. Time to track down a new power valve in the morning. Hopefully it makes a big difference. Hopefully someone has one in stock so I can run some TnT.
  5. #65
    Apr 2007
    Independence
    482
    Went to TnT tonight. Best run was:
    60' 1.747
    1/8 8.487
    1/4 13.280
    MPH 102.42
    Nothing to brag about, but it did better than I thought it would and it was my first time. I must say, I'm hooked. I'm already wanting that 12.999999.
  6. #66
    Milford OH
    1,313
    Quote Originally Posted by 98stangv6 View Post
    60' 1.747
    1/8 8.487
    1/4 13.280
    MPH 102.42
    Nice, especially for the first time out !!!
    Scott
    93 Coupe
    66 Fastback
  7. #67
    Good on that, glad it's starting to work out for you.
  8. #68
    Apr 2007
    Independence
    482
    Would switching from my 600 cfm vacuum secondaries carb to a 650 Double Pumper be beneficial to my combo? Also might go with 4.30s over the winter.
  9. #69
    Nov 2008
    Georgetown Ohio
    931
    nice project. keep up good work!
  10. #70
    Apr 2007
    Independence
    482
    It's been a long winter. Finally got to pull my junk out of the garage today.
    http://www.youtube.com/watch?v=lZ-r_gtG1bk
  11. #71
    Apr 2007
    Independence
    482
    Getting a little bored this winter...
    [IMG][/IMG]
  12. #72
    Sounds good! Hope to see it out come spring!
  13. #73
    Apr 2007
    Independence
    482
    Haven't updated in quite some time. I've found a few deals on some used junk and made a few changes. Bolted on a set of old Trick Flow Twisted Wedge 170 heads and switched to a new 650cfm mechanical secondaries carb. My main focus this winter has been drivetrain. My goal is to drive to the track and run on sticky tires without worrying about breaking. I acquired a TKO600 with CF dual friction clutch. I am also upgrading to a set of Moser 31 spline axles and 31 spline trac lok.
  14. #74
    Nice parts!!! That should make a big difference!
  15. #75
    Apr 2007
    Independence
    482
    Making a few winter changes.
  16. #76
    I bet that will make a little bit of a difference!!!
    Switching over to fuel injection also. Going with a stock computer and harness or an aftermarket set up?
  17. #77
    Apr 2007
    Independence
    482
    I'm going to give Megasquirt MS3x a try.
  18. #78
    Gotcha. Ive never ran the Megasquirt but there are people out there that like it. As long as it is fairly easy to tune, you should be good.
  19. #79
    Milford OH
    1,313
    Post back with how you like it etc.....I'm thinking of an aftermarket EFI for my 93, some seem overly complex to me, but I'm not the brightest for sure
    Scott
    93 Coupe
    66 Fastback
  20. #80
    Aug 2011
    Manchester, OH
    607
    If you want easy to tune and simple to install check out thed stinger performance PiMP XS ecu I am running it in my turbo notch. Tunerstudio is really user friendly
    1992 lx 5.0 5 speed stock and slow but looks good!
