Thanks Jason!
Thanks Jason!
1992 Mustang LX Coupe, 302, PA C4 and On3 70mm.
1993 Reef Blue hatch, 347, 3550, and a kit.
1992 Gould GT project...
Haha I got a grinder, sawzall, welder and the metal. Its not that I cant do it, I lack a little confidence since I haven't ever done one before. Im always up for some help and someone showing me once!
Installed the center section so I could measure for a drive shaft. I was just going to use the aluminum driveshaft from the yellow car and have it cut down but Id rather just use a stock steel drive shaft since its smaller diameter. Space is going to be limited...
I ordered some header flanges and 1 5/8 tubing so I can make a set of headers. Ill have a couple different sets I can swap back and forth depending on how I feel! These will just be 15 inch long primary tubes coming straight off the flanges. Next set will be the Lakester style with 3 1/2 inch megaphones and turn outs. Ill post up pictures when I get them done.
Looking forward to some pictures. This is going to be an awesome weekend cruiser!
Joe
Rather than watching football and being pissed off all weekend because the Bengals lost, I stayed in the garage as much as I could and worked on the Model A. It makes me happy knowing that I actually made something for it. I have the knowledge and most off the tools but sometimes I lack the confidence. And Im a tight ass so I hate to pay for metal and screw it up!!
Well anyways, I ordered a set of Patriot header flanges and some 1 5/8" pipe. I cut the 5ft. section into 4 pieces of 15 inches. Smashed the end of the tubes in the vise to fit the 1 3/4 inch holes in the flange. Got the tube to fit and welded it on the inside of the flange. Im going to have my buddy finish welding them on the outside so they don't look like crap!!! Tonight I took a piece of 1 3/4 tubing and made a template for how I wanted the taper done. Laid it all out, marked it, and cut close to the lines with a cutoff wheel. Then I cleaned it all up with a disc. I think they turned out pretty good for my first time. I know its nothing like what Rob Lewis or any other fab shop would do, but I did something for it that Im pleased with. Now to start on the drivers side!!
Boy that's going to be loud! Looks good Brian, trial and error!
#9 2011 Spring Street Car Shoutout
1991 Mini Tubed Mustang Coupe, in the works.
351W base, PG, Stock Suspension chassis
Nice! GoNna Be A FlameThrower
Yeah its probably not gonna pass any noise laws but that's fine for me! I will have a set of lakesters that Ill run as well if I don't like these.
Here is a video of Damon Marshall's truck. Its a little loud.
https://www.youtube.com/watch?v=cD-qfkLx0-8
Looks good nice work.
2001 Cobra Sold
1992 Mustang GT 80k M.I. couple bolt on's.
Thanks! Im happy with how its turning out. I still have a long way to go but Im getting closer. Hope to have it fired up in a few months. Still need a lot of parts.
Picked up some more parts from Ricky (Evolved) last night.
Foxbody timing cover, intake gaskets, pulleys, small bell C4, and a stock driveshaft. Im getting a little closer to firing this thing up!
I've still got valve covers and a tach for you Brian... They'd be perfect for this thing!
Coming along, looking good!
Thanks Shayne!
Chris Im still looking for some of the old finned ones. If I don't find any soon, Ill get with ya. I have a set of the finned Ford Racing ones but I don't want to use them either if I don't have to.
