Results 1 to 4 of 4
Thread: SBE 3V - Build
    Jul 2016
    Troy , OH
    476
    SBE 3V - Build
    So I took the Whipple off the 3V and have gone turbo. Here are the full build specs:
    VS Racing 76/68 .96AR T4 Turbo
    Turbonetics Wastegate
    Tial BOV
    Custom fabbed turbo kit - hot / cold side / downpipe / exhaust - 3" / 3.5" 304 stainless - Jason Zimmers
    Holley Sniper Gen 2 Intake
    ID 1050X Injectors
    CX Racing PS / Coolant overflow tank relocation
    On3 E85 Return Fuel System - 10AN Feed / 8AN Return w/dual pumps
    UPR Chrom Moly K member
    UPR Chrom Moly double adjustable Upper Control arm / spherical bearings
    UPR Chrom Moly double adjustable Lower Control arm / spherical bearings
    Same trans / rear end - just changed gears to 3.55's from 4.10's
    Hoping to see some 10 second passes on the SBE 3V before putting in the forged short block.
    Link to large picture post
    https://imgur.com/a/wn1uGSg
    LS Swapped - Locally hated now
    Jul 2016
    Troy , OH
    476
  3. #3
    Jul 2016
    Troy , OH
    476
    Dyno pull before the carnage - Found the WG had a 9 and 5 psi spring in it so pulled that out and put a 7 psi one in. When it was on 13 - 14 psi and about 8 degrees it made 455HP / 468 TQ. On about 5 psi / 13 - 15 made about 405HP / 428TQ but the boost came in later so putting a manual controller with a check valve to bring in more boost .
    https://youtu.be/m9P16Q4CSEE
  4. #4
    Jan 2009
    Hillsboro, Ohio
    7,916
    Nice!!! The turbo will make all the power you want and then some! Just keep cranking it up!
    Jason has always done some nice work. Havent seen much from him lately though.
    1992 Mustang LX Coupe, 302, PA C4 and On3 70mm.
    1993 Reef Blue hatch, 347, 3550, and a kit.
    1992 Gould GT project...
