Page 2 of 9 FirstFirst 123456 ... LastLast
Results 21 to 40 of 172
Thread: 1992 Coupe project
  1. #21
    Ok, Ill get back on this...
    Didn't do much to the car this past year. Pretty much just drove it around and enjoyed it. I went to the track a few times as it sat. Best pass was a 12.67@ 107. Still bone stock on 6lbs.
    Went down to Williamsburg for the Airport race and had a blast down there. Hopefully they can get the township to let the continue it this year. They fought it to the end with no good outcome...
    FB_IMG_1566786108455 by Brian Mcwhorter, on Flickr
    FB_IMG_1566786606621 by Brian Mcwhorter, on Flickr
    FB_IMG_1566785904968 by Brian Mcwhorter, on Flickr
    FB_IMG_1566713345482 by Brian Mcwhorter, on Flickr
    FB_IMG_1566785965877 by Brian Mcwhorter, on Flickr
    FB_IMG_1579447887250 by Brian Mcwhorter, on Flickr
  2. #22
    I was going to throw the Holley heads and Systemax intake on it but Shannon made me a killer deal on his old motor.
    Stock bottom end with AFR 165's, Anderson N412 cam, and Systemax intake.
    20191208_155524 by Brian Mcwhorter, on Flickr
  3. #23
    While I was down there made a deal on the black car.
    20191019_120020 by Brian Mcwhorter, on Flickr
    20191019_115941 by Brian Mcwhorter, on Flickr
    20200120_191423 by Brian Mcwhorter, on Flickr
  4. #24
    Spent a little bit of time on the dyno trying to get the red car to make some power.
    20191214_132359 by Brian Mcwhorter, on Flickr
    Mike did a great job working on it. Fighting through issues with the boost controller and the wastegate. Still managed to pick up around 75 hp and a bunch of torque. Once I get the new wastegate and controller on it, Ill be taking it back to see what we can do... Unless I get the Marti report back and the numbers are lower than what I original thought. Just the cheap report shows its 1 of 328. Ill be getting the deluxe report here soon.
  5. #25
    Jan 2010
    Pittsburgh, PA
    298
    Liking this!!! Start a thread on the black coupe. It looks nice.
  6. #26
    Quote Originally Posted by TooFast98Cobra View Post
    Its a nice little coupe. Dart SHP 363 with a 5 speed. Still full weight with air and power steering and full interior. It runs pretty good. I went 10.24@133 I think in it. I know Shannon has been 9.80's or .90's in it. I didn't make but 4 passes in it last year.
  7. #27
    Looking for a set of 28 spline, stock length, 5 lug axles to swap it over. If any one has a set, let me know.
  8. #28
    Started the engine removal today. Guess Ill go ahead and put the new engine in and see where it goes from there.
    20200306_190227 by Brian Mcwhorter, on Flickr
    20200306_190219 by Brian Mcwhorter, on Flickr
    20200306_190402 by Brian Mcwhorter, on Flickr
  9. #29
    Questions about the header wrap... Leave it on or take it off? Ive read somewhere that its not good to have it on. Causes cracking. My last set up wasn't wrapped.
  10. #30
    I say leave it wrapped
  11. #31
    I think Im going too. Ive been reading up on it for an hour now. Seems like most people don't have any issues with cracking that I could find.
  12. #32
    Germantown
    5,675
    I'd leave it on, the heat containment alone is worth the risk.
    Rick
    Rick90lx@yahoo-dot-com
    6.27625 liters of turbocharged goodness
  13. #33
    Im just going to leave it on. Makes it a pain in the ass putting the headers on but Ill get it.
    Im going to try to get it finished up tomorrow and running. I have a transmission leak I need to fix too while its out.
  14. #34
    Jan 2005
    Dayton
    1,301
    I had my long tubes wrapped. I loved it. Never had any issues with cracking.
    Sent from my SM-G965U using Tapatalk
  15. #35
    Engine is out... Id like to get the engine bay painted while its out.
    20200308_150138 by Brian Mcwhorter, on Flickr
    Bought a new (stock) oil pan and drilled it for the 10an fitting. Rob Lewis welded it up for me. Got the pan installed.
    20200324_125923 by Brian Mcwhorter, on Flickr
    20200324_165550 by Brian Mcwhorter, on Flickr
  16. #36
    Nice! Good to see you're getting some work done on this one. Can't wait to see it out and see what you can get out of it.
  17. #37
    Ill have this one running soon and back to getting some tuning done. Still just a stock block motor so it will be limited some.
    Still up in the air on how I want to go with this one. Its a fairly low number car so I don't want it to spiral out of control.
  18. #38
    Jan 2005
    Dayton
    1,301
    Everyone says that lol
  19. #39
    8,829
    ...........Its a fairly low number car so I don't want it to spiral out of control.
    Oh come on! WHERE'S THE BEEF? You know its going on corn and FI.
  20. #40
    Def run it on corn for that safety. Just go as fast as you can go on the setup. Race yourself, there always meat on the bone!
