Page 12 of 22 FirstFirst ... 28910111213141516 ... LastLast
Results 221 to 240 of 437
Thread: 2010 Dirty Dozen Discussion Thread
  1. #221
    Jan 2005
    dayton, ohio
    528
    Craig hp is hp. It doesn't matter if it's a 408 making 296 hp. If it weighs the same It will run close to those times and runs the same et it's making 296. I've seen 310 cube inch motors make 490 rwhp. Just because it's a 331 doesn't automatically make it make 400rwhp.
  2. #222
    Jun 2004
    Middletown
    2,481
    It should. It had twisted wedge heads x cam victor intake 30lb injectors and a fresh 331 10.5/1. It should have been at least in the 350 range.
  3. #223
    Quote Originally Posted by Metcalf Racing View Post
    The 347 I bought from Mike had unported Track Heats, small .502/.522 lift blower cam, Victor 5.0, and 9:1 compression made 341hp and went 12.06 in a full weight GT...
  4. #224
    Jun 2004
    Middletown
    2,481
    Exactly
  5. #225
    Feb 2008
    dayton,oh
    118
    im gonna have to agree if i had a stroker motor with h/c/i and it doesnt AT LEAST make the same hp as my c.i id be pretty upset with it lol
  6. #226
    Jan 2005
    dayton, ohio
    528
    Exactly what I'm saying. Ur 347 didn't make 1hp per cube and neither did his 331. This isn't out of the norm. I've seen tons of 347s make 350-380. And they didn't use a cam from 1991. The dyno doesn't lie. If the a/f is good and not pig rich then that's what it makes. My old 306 made 360rwhp on the same dyno tuned by the same place. Na is na there isn't alot to tuning it. Not all motors are created equal. Attention to detail makes power. Low peak power cam mixed with a 7k intake usually doesn't work well unless u degree the cam to make power higher.
  7. #227
    cincy
    384
    Friday on cincy speeds dyno I put down 446hp and 387 tq. I dont know what motor hp would be, but it should be around 500.
    XTREME 8.5
    HOUSE OF HORSEPOWER
    S & M MOTORSPORTS
    BARKER MACHINE & FAB
    MAC TOOLS Sam Tino
  8. #228
    Quote Originally Posted by mfoss View Post
    Thats a hot motor right there.
  9. #229
    Jan 2005
    dayton, ohio
    528
    Really hot. I'm not that hot yet.
  10. #230
    Mar 2009
    Amelia
    3,026
    Went to edgewater friday and saturday for umtr. First night out it went 10.88@126. Saturday it went 10.78@127.40. ALL MOTOR
    This is my combo.
    331
    twisted wedge trickflows (no portwork)
    vic jr intake 750 carb
    anderson cam
    tko trans
    it looked really good too.......... I introduced myself to you at the track looking for silicone.......
  11. #231
    Jan 2005
    dayton, ohio
    528
    What tires did u dyno it on?
  12. #232
    cincy
    384
    Quote Originally Posted by flyin2jz View Post
    26X8.5 HOOSIER SLICKS
    XTREME 8.5
    HOUSE OF HORSEPOWER
    S & M MOTORSPORTS
    MAC TOOLS Sam Tino
  13. #233
    Jan 2005
    dayton, ohio
    528
    It's most likely making more power than that. The slicks will eat power and tq on the dyno as they start sticking to it. Don't believe me put some regular radials on it and it will pick up 25rwhp. I've tried it. I believe ur 331 has the highest hp numbers I've ever seen. Most are in the low 400s
  14. #234
    cincy
    384
    I was going to put regular radials on but didnt have any. I did pick up 5rwhp with my 2010 camaro when I added air to those radials.I went from 32 to 45. When I get the car to hook better and figure out the clutch, I think it should run high 40s to low 50s. When I built this motor I was hoping for some high 10s low 11s. Im happy with the results.
    XTREME 8.5
    HOUSE OF HORSEPOWER
    S & M MOTORSPORTS
    MAC TOOLS Sam Tino
  15. #235
    Franklin Twp
    1,289
    Awesome times MFoss! Which AFM cam are you running?
    Rich Taylor
    92 Mustang LX 357w...Carb'd!
    10.83 @ 124mph
  16. #236
    Jan 2005
    dayton, ohio
    528
    Most likely n91 or 111
  17. #237
    cincy
    384
    yea its a n91
    XTREME 8.5
    HOUSE OF HORSEPOWER
    S & M MOTORSPORTS
    MAC TOOLS Sam Tino
  18. #238
    May 2006
    Springfield Township
    2,629
    i made 357/357 with out of the box tw170's, victor 5.0 efi intake and a small street cam ... all on a 331 ... thats about what you will see out of 99% of your stroker builds ...
    i have a friend in south carolina that made 456 rwhp on a 331 ... HIGH DOLLAR parts, big $$$$ ... the twisted wedge cnc ported 205's, with a very light valve train ... he ran the anderson N91 cam, he had 11:1 compression and a hogged out trick flow r box intake ... 90mm maf, 90mm tb, 1 3/4 long tubes, lots of rpm (7200) and lots of tuning ... it takes come serious coin to put down 430-450+ on these little stroker motors ... 1.4 hp per cubic inch takes $$$$$$$$$$$ ...
    Coin or labor, you're going to pay to go fast ... i chose the labor route ... 110 hours on the heads, 20 hours on the upper intake and need another 30 hours to do the lower intake ... im only hoping for 410+ hp ... 10's on a street car granny shifting and im good to go
    331 Mexican, TW205's, tf box r, Cam Motion Cam 10.41 @129.12
    11.38 @119 http://www.youtube.com/watch?v=iXfVgm9jpd0
    10.98 @123 http://www.youtube.com/watch?v=xBgUh...=youtube_gdata
  19. #239
    Jan 2005
    dayton, ohio
    528
    It's very hard to believe the heads are box stock. I've seen many cars with this exact combo making low 400s. Somehow u have found 46 more than 99% of 331s with ported everything. Goes to show what a good carb can do. Very nice work.
  20. #240
    colerain
    985
    those heads are box stock and you are right amazing what a good carb and compretion will get you . most of the combos you see out there are 10to 1 11 to 1 add 3 or 4 points of compretion wakes that bitc. up
    house of horspowerold school dirty dozen member back when the list was fast and post counts did not matter !:
There are currently 9 users browsing this thread. (0 members and 9 guests)
