Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 85
Thread: 1992 LX Hatch Coyote Swap in Progress
  1. #21
    Cant wait to see how this turns out!
  2. #22
    Sep 2009
    Williamsburg, Ohio
    382
    Are you going to the use oil cooler that came on the engine? Mine has that too, and debating on using it. I like the potential benefits of it, but it clutters things up a little.
    Are you swapping the front cover or just taking it off to install oil pump gears?
    2011 F150 FX4 SCREW EB
    1997 Cobra Coyote Swap w/IRS project in progress slowly....
    89 Mustang SSP 5.0 Turbo -Gone
    03 SVT Focus Turbo -Gone
  3. #23
    6,320
    I took the water pump off next.
  4. #24
    6,320
    Thanks!
  5. #25
    6,320
    Quote Originally Posted by egbertnr View Post
    No, we are not using that oil cooler. I'm just waiting til we get a different one before I swap it out. Yep, replacing pump gears. Have to upload more pics, which takes an incredible amount of time with photobucket for some reason. Keeps locking up my computer. Using TSS gears in the pump.
  6. #26
    Sep 2007
    Kettering
    571
    Looks good nice work.
    2001 Cobra Sold
    1992 Mustang GT 80k M.I. couple bolt on's.
  7. #27
    6,320
    After the balancer was removed, I took the timing cover off. This pic shows the positioning of the timing cover bolts.
    Which exposed the chains.
  8. #28
    6,320
    I took the chains off(there is a procedure for that that must be carefully followed), to get to the oil pump. I removed the oil pump and opened it up.
    I put the billet gears in the housing and lubed them up with vaseline for a quicker prime.
  9. #29
    6,320
    Not sure if we are going to use this cover or not. Depends on if it works with the brackets we are getting for it.
  10. #30
    6,320
    After I installed the oil pump and timed the engine again, I put the timing cover back on, and loosely installed the balancer in case it had to be taken off again. I then flipped the engine and took the oil pan out of the box for a test fit. The oil pump pick up is the same from mustang to truck. However, the oil pan gaskets are different between the two. I had to modify the pick up with a block of wood and a hammer to get it to clear the bottom of the pan and the edge of the sump.
  11. #31
    6,320
    This is the difference between the truck oil pan gasket(right) and the mustang gasket(left). As you can see, the mustang gasket is also a windage tray. I'm going to use this gasket with the canton pan. I will post up if there are any issues, but I doubt it. I think it'll be worth a few ponies on the dyno, worth a shot at least.
  12. #32
    Sep 2007
    Kettering
    571
    Nice work.
    2001 Cobra Sold
  13. #33
    Coming along nice!
  14. #34
    6,320
    This is how the pick up tube mounts, and I was putting the new mustang oil pan gasket with windage tray on it. The gasket goes on first, then the pick up goes in and tighten all the bolts.
  15. #35
    6,320
    We decided to go with the Power by the Hour accessory bracket kit that uses the 5.0 alternator but uses 96 up accessories like a/c compressor and p/s pump. I put the p/s bracket on first because the instructions said to. I read the instructions thoroughly and even asked the guy if this would work with the truck timing cover. This is how it looked:
    You can see that there is an empty bolt hole on the cover. I researched it and found that the only cover that will work is this one:
    I believe that is the part number, but I will double check when I get to the shop and verify.
  16. #36
    6,320
    So off came the timing cover, which really sucks since I had it all together:
    Put the new cover on:
  17. #37
    6,320
    Now you can see how all the bolt holes line up and the bracket is moved further up the side of the engine. It works as it should and all the instructions make sense now with this cover. The pictures match up as well in the instructions now. I bolted the bracket up correctly.
  18. #38
    6,320
    As I was putting the mustang cover on and the bracket, I realized the goofy truck oil cooler would not work with the new cover, so I had to buy this one:
    This is a pic of both of them. Luckily the bolts from the old one work with the new one:
  19. #39
    6,320
    More pics of the bracket properly installed and the mustang oil filter adapter:
  20. #40
    6,320
    Next, I mounted the p/s pump onto the new bracket and timing cover. It fit perfectly.
    This bracket kit really is a nice, high-quality kit. Instructions are great, and with what I've written here, you should be able to get it on your project just as easily.
