Page 47 of 59 FirstFirst ... 3743444546474849505157 ... LastLast
Results 921 to 940 of 1171
Thread: 91 Mini Tubbed Mustang Coupe
  1. #921
    Quote Originally Posted by k062693w View Post
    That's a really pretty Green Shayne !!!
    Looks Good ...
    Your not supposed to be looking at the blower Aaron. Lol
  2. #922
    That thing would look badass if it was dark metallic gunmetal!
    You don't think it does already Walter?
  3. #923
    More to follow soon.
  4. #924
    New spacer
    Sent from my Z965 using Tapatalk
  5. #925
    Had to weld a bung onto the radiator for the water temp sending unit.
  6. #926
    Do you run a thermostat?
  7. #927
    Nice! You running that under the nitrous plate or are you planning on running a fogger?
  8. #928
    I am not Walter.
  9. #929
    I will be running a single stage plate Brian.
  10. #930
    There is no thermostat housing on this intake, each water jacket is ran with a -12 braided line. I can always install restrictors if needed.
  11. #931
    Either way, it sure looks good!!
  12. #932
    I would like to plumb my carb spacer with the nitrous spray bars.
  13. #933
    This thing has been sitting way to long!!! You have to be almost ready to make some passes!!!
    Whats left?
  14. #934
    I've ran into a couple issues, hopefully be able to soon.
  15. #935
    Quote Originally Posted by 2Fast4You View Post
    What happened
  16. #936
    You're gonna miss out on some good weather coming up!!!
  17. #937
    What happened
    Had to pull the trans back out do to a leaking shifter shaft seal, that meant the whole exhaust had to come out as well etc.
  18. #938
    Should've tried some flex seal!!!
    Sucks though that it had to come back out to fix one small problem. Nothing is ever easy.
  19. #939
    It was a bad leak, not sure anything would have helped other than replacing it. It was inevitable, it was easier to just fix it now. Just typing about makes it sounds easy, but when your car is only inches off of the concrete floor, it's another whole story. It should be out soon though.
  20. #940
    Had some throttle linkage issues as well, I hope this helps. I couldn't get the throttle past 3/4 of the way, this will raise the point at which it was able to mount before. It also gives me a little more travel on the throttle, time will tell.
There are currently 9 users browsing this thread. (0 members and 9 guests)
